Need help with relay - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-25-2011, 02:00 PM Thread Starter
I have a relay switch that I use for arming and activation switch. I just bought a bottle heater and was wondering, can I run wires to that relay from the heater? And will it not affect the arming and activation switch?
Spencer
mustang32cobra is offline
post #2 of 4 Old 02-25-2011, 02:06 PM
raceoholic330's Avatar
Trader Feedback: (46)
If you only want the heater to turn on when the arm/activate switch is on, then that should be okay as long as you are not overloading the current rating of the relay.
-Scott
88 GT
Turbocharged Dart 331 & complete resto in the works...
raceoholic330 is offline
post #3 of 4 Old 02-25-2011, 02:15 PM Thread Starter
Awsome!
I will do that and see how it goes
post #4 of 4 Old 02-26-2011, 12:44 PM
asiansensation78's Avatar
Here's the wiring setup you'll want to run for your bottle heater:
Pin:
30: +12v from battery
85: ground
86: +12v trigger from switch
87: +12v output to heater
87a: not used
Hope this helps!
-Jerry
2003 GT Vert, bolt-ons, nitrous, conservative tune
mustangkeyless.com
asiansensation78 is offline
Will a standard 30amp relay work for Taurus Fan on Low? Nitrous SSC General Mustang Tech 18 07-06-2014 11:55 AM
Starter relay okay to get wet??? 93BLKNotch 5.0/5.8 Engine Tech 6 12-14-2010 09:06 PM
88 sd harness, fuel pump relay ? ndmus88gteng General Mustang Tech 5 11-17-2010 01:33 PM
Help a wiring retard - RELAY Vettkilr 5.0/5.8 Engine Tech 2 12-16-2001 07:59 AM
