3g alternator pulley getting really hot??????????? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-24-2011, 10:05 PM Thread Starter
purplevert's Avatar
I have a 88 that i converted to a 3g alt. I started it today and let it run maybe 60 seconds and felt the pulley and it real hot. Felt like it would melt the belt if I let it run any longer. I took it to have it checked and it checks out good. The pulley turns freely. It doesnt seem to charge as well either. Please help thanks
purplevert is offline
post #2 of 4 Old 02-24-2011, 11:42 PM
66mustfb's Avatar
If the pulley on the 3g is smaller in diameter then the one you replaced you may not have enough belt tension and the belt is slipping at the crank.
'66 fastback w/MegaSquirt II, MAF & EDIS, 5.0L 2k Exp, Fuel Safe, Total Control R&P, 4w Disk, T5z, Hyd Clutch and 8" 3.55
66mustfb is offline
post #3 of 4 Old 02-25-2011, 07:40 AM Thread Starter
purplevert's Avatar
the belt is tight and why would it get hot after only a minute
post #4 of 4 Old 03-06-2011, 01:27 PM
Like he said belt is slipping. Been there done that. Hot in seconds!
HLD-TYT is offline
Hot Rod Black Death.....920whp Terminator vegasse The Body Shop 14 02-16-2011 12:37 AM
my 90 coupe is running hot. HELP!! yuba200311 5.0/5.8 Engine Tech 7 01-26-2011 10:16 PM
Car won't start when hot Jman 94/95 Tech 6 05-13-2002 10:26 PM
Running hot after radiator install? AlanJames95gt 5.0/5.8 Engine Tech 3 12-23-2001 04:43 PM
Help! T-5 "won't" shift when hot! Maverick1970 General Mustang Tech 6 11-30-2001 09:02 PM
