Turn the key and all I hear is CLICK - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-19-2011, 01:49 AM Thread Starter
Hi I have a 90 2.3l Mustang. The starter is good Had it checked the solenoid is new, 2 days old.The battery is good It will start my pickup truck... What could be the issue with this??? Thanks
bandb is offline
post #2 of 4 Old 02-19-2011, 11:49 PM
Sometimes it can be a corrosion problem with the cables or connections. How do the cables look at the battery terminals.Clean and tight?I had a starter doing the same thing once. About a inch of cable was corroded at the positive terminal.Cut it off and replaced the terminal.Worked great since.
TWINTURBOCOUPE is offline
post #3 of 4 Old 02-24-2011, 02:47 AM
riored94cobra's Avatar
+1
I had a very similar issue. Mine was corroded on the negative side tho. It had the same symptoms your car is having.
riored94cobra is offline
post #4 of 4 Old 03-31-2011, 01:55 PM
GUNRUNINPONY's Avatar
Also check the block ground, had those loosen in the pass and cause the same problem!
A wise man once said "It's better to remain silent and appear ignorant, rather than speak and remove doubt!
91 GT, TT 306,TFS 170's, Track Heat,60lb inj, 150 shot, 3.27's, setting up for nice dd with Maximum Motorsport suspension.
GUNRUNINPONY is offline
