power window electrical problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-18-2011, 09:08 PM Thread Starter
hi guys ive got a problem with my passenger side power window that is cureently not working.i have 12 volts dc on the pink wire at the switch.when i unhook the motor and put my meter leads on the tab inside the quick connect for the motor i have 12 volts to ground when the switch is in the down position on the red wire and 12 volts to ground when the switch is in the up position on the yellow wire.i took the switch out of the circuit and checked continuity and all is ok with the switch.the problem comes when i plug the motor up.with the motor plugged up i have 12 volts on both the red and yellow wires whether the switch is in the up or down position.my first thought was a faulty motor so i removed the motor from the drivers side and plugged it in and got the same result........any ideas????
skeezer is offline
post #2 of 3 Old 03-21-2011, 03:09 PM
i think i'm having the exact same problem with my drivers side window did you find a fix?
inca1982 is offline
post #3 of 3 Old 04-01-2011, 06:28 PM
Have you tried a set of jumper wires from your battery to the motor to see if it is working right? If you have voltage when you push the switch and thats working right I would say replace the motor. Is your other window working ok?
gt92mustang is offline
FR500TT Big Bore Boss-Stroked and Boosted w/Ethanol! Turbo98 SVT & DOHC 359 12-10-2012 09:05 PM
Power Window support is trashed - what to do? Jeff Dude GT & SOHC 5 02-18-2011 07:50 AM
power window problems...87 coupe bottlefedgt General Mustang Tech 5 11-17-2010 08:01 PM
Power window problems Saleen308 General Mustang Tech 1 12-22-2001 11:09 AM
