wiring question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-17-2002, 06:03 PM Thread Starter
wiring question
I'm trying to install a fuel/air meter, and a fuel pressure gauge. The fuel/air meter has 3 wires. red, black, purple.
Red: power
black: ground
purple: O2 sensor signal wire
How do I find where to connect the O2 sensor signal wire, and also do you have any suggestions for good power/ground wires in the proximity of the A pillar where my gauges will be mounted.
Any help would be great.
94 teal GT 5 speed, pullies, hypertech chip, 3.55s, K&N, hurst shifter, offroad h-pipe, 14.8 @ 95.5mph.
GoGreen is offline
post #2 of 2 Old 06-17-2002, 07:29 PM
I would run the power and ground wires down to your fuse box and hook them up there. As far as the 02 sensor goes, I would tie that in at your computer (behind the kick plate on the passenger side). Not sure which pin it is, but you should be able to find it on a electrical schematic.
pharrgon is offline
Coyote swap wiring question. T_Cahill General Mustang Tech 6 11-18-2015 12:58 AM
95 cobra battery relocation wiring question First5.0L 94/95 Tech 2 08-06-2013 04:27 PM
egr delete wiring question. 65_mustang_kid 5.0/5.8 Engine Tech 2 08-03-2013 01:31 PM
wiring question gambling209 General Mustang Tech 1 05-06-2013 12:08 PM
2000 gt alternator wiring question pcspeedworks GT & SOHC 0 11-24-2012 08:31 PM
