Where is the turn signal and airbag fuses located? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-06-2002, 10:53 PM Thread Starter
VIPERBLUELX's Avatar
For whatever reason my turn signals stopped working and the airbag light come on yesterday. Anybody know what fuse location each is in?
thanks
mark sexton
VIPERBLUELX is offline
post #2 of 5 Old 06-07-2002, 06:49 PM Thread Starter
post #3 of 5 Old 06-07-2002, 09:59 PM
stangPlus2Birds's Avatar
What's the air bag code?
Joe - 86 Mustang GT with ABS!
M-2300K brakes, Mach1 Springs, D178 rims, and 245/45/17 RE730 tires. Car Pictures: http://www.veryuseful.com/mustang/tech/misc/Mustang1986_with_Mach1_springs/
stangPlus2Birds is offline
post #4 of 5 Old 06-09-2002, 01:29 PM Thread Starter
I haven't ran the codes, the light just started staying on the same time the turn signals quit working.
post #5 of 5 Old 06-09-2002, 01:50 PM
Just look at the air bag light when you turn the car on.
o Diagnostic trouble codes, if present, will begin flashing within 30 seconds after the ignition switch has been turned to RUN. This is the amount of time it takes the air bag diagnostic monitor to perform all tests and verify system faults, if present.
o Diagnostic trouble codes are displayed as a series of flashes and pauses of the air bag indicator. Diagnostic trouble codes are two-digit numbers.
Example: A DTC 32 is displayed as follows:
flash flash flash - (two second pause) -
flash flash - (five second pause)...
