CCRM - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-05-2002, 02:42 AM Thread Starter
CCRM
Hey how can you tell if there is a problem with the CCRM withoug actually taking it to Ford so that they can take my money doing tests and end up finding nothing. Will it make the car do anything different? or anything that I will notice?
Prince95 is offline
post #2 of 4 Old 06-07-2002, 08:48 AM
KJ94GT's Avatar
What problem are you having that makes you think there's a problem in it? The CCRM houses several different devices like the fuel pump relay and some other junk. Post up!
94 GT C4 transmission, SVO block'd 331, 160# injectors, 2 fuel pumps, 10pt cage and a big turbo
http://www.dfwmotorsports.net
KJ94GT is offline
post #3 of 4 Old 06-07-2002, 12:48 PM Thread Starter
I was figuring that since my fan comes on to late and at to high of a temp and turns off to soon. Maybe the CCRM is causing this. I already tried changing the ECT, maybe it could be the fan. Although the ECT I did buy was plastic
Prince95 is offline
post #4 of 4 Old 06-08-2002, 11:00 PM
KJ94GT's Avatar
If you have a Haynes Manual, there is a write-up in there about what all is housed in the CCRM.
KJ94GT is offline
Fuel Pump and Fan Run With Switch On Josh93 SVT & DOHC 30 07-01-2015 12:08 AM
Ditching the CCRM kbscobravert 94/95 Tech 14 07-03-2014 05:29 AM
Need help ditching my CCRM kbscobravert Electrical & Wiring 7 03-06-2013 10:42 PM
98 GT Won't start. No Injector Pulse. No power to fuel pump. Shawn 94 GT GT & SOHC 11 10-23-2012 07:48 AM
Bondurant Electrical Wiring Fan CCRM A/C WOT Cutout Modification rallycobra Road Racing/Auto X 1 06-26-2012 12:24 PM
