460rwhp+3600lbs=what size ET street? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 03-06-2003, 02:54 PM Thread Starter
ponyboy19's Avatar
I'm toying around with the idea of buying a set of ET streets to see what breaks first.. block, tranny, or stock rear end My race weight would be around 3600lbs, it's making 461 rwhp, has 3:73's with a T5. I was thinking 26-10.5-15 but i see MT is making it in a 27 and a 28 so i'm just not sure how tall of a tire would be best for my car.. any suggestions?
95 GT
9:1 Dart Block 418w, Vortch YSi, Pa C4 super comp,
92 Gt,
ponyboy19 is offline
post #2 of 7 Old 03-06-2003, 03:22 PM
paluka21's Avatar
I would say stick with a 26x10.5" slick for your power level and 3.73's. a 28" tire will be too tall for you no matter who says it will give you more mph. I went 119mph with 464rwhp and a 3550lb race weight on a 26' nitto drag radial. I went 116.5mph on a 28" Et street, so that should tell you what too tall of a tire will do.
later
DAN
95 rio red cobra #2021
2014 Shelby GT00- Oxford White/Sonic Blue Stripes
1995 Rio Red Cobra #2021 - SOLD
8.8:1 comp. Dart 331, Procharger D1 16psi, AFR 185, Edelbrock RPM II, custom cam, TKO, Glenns 1000hp fuel system.
690rwhp on Mustang dyno
paluka21 is offline
post #3 of 7 Old 03-06-2003, 04:58 PM
I'd be looking at a 26x11.50 on an 8-10" wide wheel. The 10.50 is a very small tire.
TC86GT is offline
post #4 of 7 Old 03-06-2003, 11:18 PM
HUB90LX's Avatar
26x10.5 will work good for you. I would start out at 14psi for your tire pressure and work from there.
HUB
2002 Mustang GT: Steeda pullies, Magnaflow catback.
1990 LX Convertable: FPS 331, AFR 185s, E cam, S-Trim [email protected] ProM 80mm, Anderson P/P, 55lb inj. no FMU, Tuned by Swanson Performance 522RWHP 507 RWTQ Wt/w driver 3690lbs. [email protected]/ 1.50 60ft.
(MM&FF Editors Choice Award) (MM&FF feature car May 04 pg. 76)
"I love the smell of race gas in the morning......It reminds me of victory"
HUB90LX is offline
post #5 of 7 Old 03-07-2003, 03:17 AM
Would there be any clearence issues? Would rolling the lip cure it?
ROADWARRIORSVT is offline
post #6 of 7 Old 03-07-2003, 05:20 AM Thread Starter
ponyboy19's Avatar
thanks for the help guys, 26x10.5 it will be then.. I have a set of V6 15x7 rims so i have to stay with 10.5" I think.
95 GT
92 Gt,
post #7 of 7 Old 03-07-2003, 08:51 PM
Depends on the rim and backspaing. I had the 11.50's on an 8.5" Centerline and had no problems, car wasn't low enough to rub the outer lip and it had plenty of room inside on that rim.
ponyboy19, good call. I wouldn't have suggested wider had I known about the narrow rims.
TC86GT is offline
