2015+ IRS setup - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-30-2019, 08:05 AM Thread Starter
2015+ IRS setup
So I have a 2015 Mustang IRS setup ready to go into my race truck. It is the 3.73 with Torsen diff. What are the first things you guys are doing to prevent wheel hop on these things? Also, since I am retrofitting this into my truck, what are your thoughts on welding the IRS subframe directly to my truck frame instead of, or in addition to, fabricating brackets to mechanically fasten at the IRS stock mounting locations?
408Stroke&Broke is offline
post #2 of 2 Old 01-30-2019, 06:48 PM
Jack Hidley's Avatar
If this is going to be a pure drag race car, you need to raise the nose of the IRS and/or lower the rear of it to increase the amount of antisquat. If the car is ever driven on the street don't do this. The higher the cg height is in the car, the more the IRS needs to be tilted to end up with 100% AS.
Welding the IRS subframe to the frame is fine, but you should only weld three points, then make the fourth point bolt together with shims. This way the the subframe will not be warped when it is welded to the frame.
For drag racing, you can replace all of the pivot points with spherical bearings.
Jack Hidley
Jack Hidley is offline
Want To Trade My SRA setup for your IRS - Sacramento or Nor Cal kbernal1016 Suspension 3 09-11-2011 03:08 AM
wtb complete irs setup eighty8gtfiveo Drivetrain Parts 13 11-21-2007 12:07 AM
For sale IRS setup from 04 cobra silver46stang Drivetrain Parts 1 08-09-2004 09:51 AM
Want to trade IRS for Live axle setup silver46stang Drivetrain Parts 0 07-20-2004 08:32 AM
Need some specific IRS differential setup advice lo pony SVT & DOHC 9 11-05-2002 01:11 PM
