331 Build ET... need help with converter/gears - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By AlexLTDLX
post #1 of 2 Old 09-24-2018, 10:20 AM Thread Starter
Post 331 Build ET... need help with converter/gears
Hello all, I have a 91 GT full weight, stock suspension with 26x9x15 hoosier slicks in the back at 14 psi on this pass. I am running the wrong torque converter I know, but I am looking for suggestions on what to buy to improve my times and any tips at all, as well as gears. Trans is a 4r70w currently running a 4000 stall, footbraking at 2000 on the tree. I am running 3.73 gears. I just feel it's a little slower than it should be and I'm probably losing a lot of my midrange powerband with this converter. Still want it streetable just want to pick some time up. See image attached for slip. Thank you
Engine setup is:
336 CI (.060 overbore 331)
Trickflow 170 heads
Trickflow Track Heat Intake
Trickflow Stage 2 Cam
1.6 Rockers
75mm TB and 80mm MAF
42lb injectors
BBK shorty 1 5/8 headers with offroad x pipe and mac pro dumps for exhaust
Stock computer tuned with Moates Quarterhorse
TCI Trans controller
hammy is offline
post #2 of 2 Old 10-08-2018, 12:35 AM
AlexLTDLX's Avatar
Frankly, I think it's running pretty well for what it is. The biggest issue I see is mild 302-sized components on a 336. When I ran a 306/TW 170 heads/ TF Street Intake and Lunati 51014, I think the best I managed was a 12.6 at 106 - probably 100-200 lbs heavier than you or more. I wouldn't mess with the converter at this point. I'd put a different intake on it and see what happens. I don't think I've ever recommended one, but your car is screaming for a Holley Systemax EFI intake. That cam isn't the greatest choice, either. Cam+intake will possibly get you high 11's with your current converter/gears. Giving the heads even a good tootsie roll job is worth about 15 cfm. That's not something I heard, that's something I did and then paid to flow them.
Do all 3, and get it down to about 2,900 lbs and you might tickle high 10's.
hammy likes this.
AlexLTDLX
AlexLTDLX is offline
Tags
331, advice, converter, gears, sbf
331 build, suggestions and input please tvolsr1 5.0/5.8 Engine Tech 2 08-21-2014 11:25 PM
Another 5.0 split block... need your help to build a Dart 331 shortblock !! the_bock 5.0/5.8 Engine Tech 60 12-13-2013 11:23 PM
Newbie with 331 build questions tapkoote 5.0/5.8 Engine Tech 1 09-17-2013 10:09 PM
First Mustang Build, Twin 62/62's, Dart 331, T56...Questions TRMIN8R Drag Racing 10 11-10-2011 12:47 PM
Next Build - N/A 302, 331, or 347 w/ 400hp kbernal1016 5.0/5.8 Engine Tech 21 10-26-2011 04:59 PM
