8.8 with spool oil recommendations - Ford Mustang Forums : Corral.net Mustang Forum
 3Likes
  • 1 Post By AtomicCoupe
  • 1 Post By Saleen414
  • 1 Post By SRTthis798
post #1 of 27 Old 08-28-2018, 05:06 AM Thread Starter
CrucialProspect's Avatar
Recently replaced factory limited slip with spool, just out of curiosity, what gear oil is everyone running? Not needing to run a additive now, is everyone sticking to a synthetic 75-140, 75-90?
CrucialProspect is offline
post #2 of 27 Old 08-28-2018, 06:00 AM
Saleen414's Avatar
I run 75-140 Royal Purple gear oil in my spooled 8.8. Currently with a 4.10:1 gear. No problems after 3 seasons.
26 X 8.5 Hoosier
Saleen414 is offline
post #3 of 27 Old 08-29-2018, 01:50 PM Thread Starter
Sounds good! Done and done!
post #4 of 27 Old 08-29-2018, 02:46 PM
No need to keep clutch packs coated so you will only need 1.5 qts.
quikbluewagon is offline
post #5 of 27 Old 08-29-2018, 03:26 PM
AtomicCoupe's Avatar
With a stock cover or extra capacity diff cover?? Why run shy? What about the ring a pinion?
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #6 of 27 Old 08-29-2018, 03:29 PM
Also I’d run whatever diff fluid is recommended by the gear company. Since there’s no locker, then it’s easy just to go by whatever the ring and pinion call for.
TomR likes this.
post #7 of 27 Old 08-29-2018, 03:56 PM
Saleen414's Avatar
If for drag racing only, no need for a full diff. A full diff of oil causes windage and drag. I only run 1 qrt in the diff. It dose not operate long enough to build any heat.
sradtodrag likes this.
26 X 8.5 Hoosier
post #8 of 27 Old 08-30-2018, 02:01 AM Thread Starter
Interesting point, with stock cover you only use 1.5qts?
post #9 of 27 Old 08-31-2018, 09:16 AM
I run a Perfect Launch diff cover and 1.5 qts of Royal Purple 75w-140 Max Gear synthetic oil. The diff cover didn't change the capacity.
post #10 of 27 Old 08-31-2018, 03:45 PM
Ok, I can see this. Drag race only I would say I agree. I run my car on the street w/ spool. I just filled it until it came out of the fill hole. Didn’t really put much thought into it one way or the other. Good info
post #11 of 27 Old 08-31-2018, 05:52 PM
Try running without oil.
You'll be surprised how much heat there is.
the cheapest 80w90 has always proven to be more consistent than 75w140 or any synthetic, at least in my case (built 9"). 14 years so far on the same gears, case, axles, everything. Knock on wood. Has not been apart or even drained, but it does build some heat after a pass even with 2 1/2 qts of lube in it.
toddturbo is offline
post #12 of 27 Old 08-31-2018, 05:52 PM Thread Starter
How horrible is it on the street? Never driven one and i figured it was a horrible idea.
post #13 of 27 Old 08-31-2018, 07:56 PM
if you drive it smartly, it’s really not bad. I Just have to remember it’s there and drive the car like it has a spool in it. It’s nice knowing the lockup is always there
post #14 of 27 Old 08-31-2018, 08:21 PM Thread Starter
Do you air up tires all the way to make it easier to skip?
post #15 of 27 Old 09-01-2018, 09:46 AM
LOL, actually yes, depending on your tires, that’s a good point. I run my tire pressure higher when I’m planning on street cruising. But again, I plan where I drive to avoid tight turns. Other than tight turns I barely know it’s there. With that said, I highly recommend sticking with a locker if any car is strictly a street car. At the power level I’m at I felt more comfortable with 35 spline axles and a spool for track use, so I have to take the good with the bad.
I think a huge factor in a cars “streetability” that is overlooked is where you live and what the road conditions are like. What works for me might not work for someone in another part of the country. My car wouldn’t last a week in a city for example.
post #16 of 27 Old 09-01-2018, 09:48 AM
I also drive with my ARB hooked up, manual brakes and manual steering. So take my advice for what it is LOL
post #17 of 27 Old 09-01-2018, 11:42 AM
Sounds like my car. The only time I drive it on the street is the occasional Friday jog to the office, a couple of car meets a month, and trips to the drag strip.
post #18 of 27 Old 09-01-2018, 02:52 PM Thread Starter
Thanks! No real street use here, I’ll wait until I can afford a locker to do that, but I was wondering about tight maneuvering between the shop and the trailer on pavement. On my trucks front axle with manual lockouts, I’m using a spool. In the grass it’s fine, but as soon as you get that traction, she starts bucking real bad! However, that is the steering axle of my toy hauler, and the spool is on the drive axles of the car, so I basically have 0 experience with one.
post #19 of 27 Old 09-01-2018, 08:53 PM
Saleen414's Avatar
I ran a spool on the street for a while, and all I remember is that in a turn at speed the car went from mild push to snap over-steer in a hurry. Lol.
26 X 8.5 Hoosier
post #20 of 27 Old 09-02-2018, 09:42 AM
TomR's Avatar
I would never run my rear end low on lube. The rear gear only turns so slow and accelerates so slow and torque is so high you would never measure the change in power, but I'd bet money it would cause a change in bearing or gear life.
I would never waste a penny on a special lube. I get about 1 to 1-1/2 years out of a gear set now that Ford gets them from Motive gear or whoever. I'm at a 60 foot time where 35 spline axles gradually twist. The issue 100% of the time is the gear teeth are too brittle and eventually start to chunk off.
I went past my normal inspection time. When I pulled the cover I could push chips out of the ring gear and pinion gear with a screwdriver. The failure issue is always a tooth fracturing or breaking off, it is never an issue from lube quality. When the gear is ready to break it will start showing different depth surface lines in the pattern either on the pinion or the ring or both. I went way past the safe point on this round.
TomR is offline
post #21 of 27 Old 09-05-2018, 07:33 AM
SRTthis798's Avatar
Trader Feedback: (15)
do they make a pro gear in your ratio?
TomR likes this.
DT Racing and Fabrication
Crew Chief
Roche Racing engines Billet headed windsor! BMF on 275s!
my car-88lx- 408" stock block gangster!!!
SRTthis798 is offline
post #22 of 27 Old 09-06-2018, 11:32 AM
TomR's Avatar
Don't know, but the biggest axles I can fit are 35 splines and they are twisting. It pushes on the pinion thrust bearing so hard it wedged the race into the case. The 1.115 sixties and 3200 lbs is probably beyond the 8.8.
I've rebuilt it all, but I think I need to upgrade to a fabricated 9" housing and 40 splines.
The nice thing is the chassis and rear suspension bolts seem to be holding up, but I think I'm at the 8.8 limits.
TomR is offline
post #23 of 27 Old 09-06-2018, 12:56 PM Thread Starter
That’s crazy!
post #24 of 27 Old 09-06-2018, 01:17 PM
SRTthis798's Avatar
yea you need a set of pro gears and a 9" with 40's
Crew Chief
post #25 of 27 Old 09-06-2018, 02:23 PM
Wow, you’re making some power!!
post #26 of 27 Old 09-06-2018, 02:47 PM
SRTthis798's Avatar
Wow, youíre making some power!!
nothing against Tom... 60' shows more of how the suspension is working than how much power you have at this level.
his suspension works thats for sure.
Crew Chief
post #27 of 27 Old 09-06-2018, 05:33 PM Thread Starter
Agreed!
Rdrcrís 2013 Mustang GT Upgrades and Reviews Thread. Rdrcr S-197 Mustang GT (2011-2014) 62 12-11-2014 12:36 PM
Oil Cooler Recommendations?? BOSSGT Road Racing/Auto X 4 08-25-2012 07:20 PM
A/C Clutch not engaging armyscout General Mustang Tech 51 06-27-2012 09:50 PM
For Sale Strange Pro Race Axles And Spool 33 Spline 8.8 ffr3247r Drivetrain Parts 1 09-01-2011 07:04 PM
