60' check - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 03-23-2018, 11:50 AM Thread Starter
5gearbanging's Avatar
60' check
Just checking my 60' times.
I consistently cut 1.83 60' times and am just seeing if I am leaving anything on the table or if its mod time.
The car will go low 1.6s if I leave on the bottle so I am thinking it might be weight loss and power time.
Car is 3280# race weight
5 spd
Mickey Thompson DR 14.5-15psi
Suspension is Ford drag Launch springs
Lakewood 90/10 Struts 50/50 shocks
HPM Mega bite upper and lowers
Spooled with 4.10s
Burnout I spin the tires in 2nd gear until I get 3sec of smoke, then roll it out.
4500rpm and dumping the clutch the car hooks
4800rpm knocks the tires off
4000rpm bogs
90 LX Notch 5.0 5spd, bolt on drag car with some giggle gas.
11.71 @ 116mph
86 Gt T-top 5.0 5spd, That one day project.
5gearbanging is offline
post #2 of 14 Old 03-24-2018, 11:09 AM
bamabox's Avatar
In the most generic of terms, launching a stick car on DRís is tough sledding. You did not mention your HP, tire size of the DRís, size of shot, etc. if the info in your sig is NA, thatís a pretty reasonable ET for the MPH. So with not much info, I would guess if you switched to a stiffwall slick you would pick up a couple tenths on 60í, and of course about double that # on the big end.
99 coupe. C4/8Ē 5000 stall w/2003 Mach crate motor FRPP stock N/A, Kooks LT's and X,dumps no muffs. 4.56's
Best ET 11.42 Best MPH 116.33Best 60" 1.49
Coincidence. A convenient and overused word for the mentally lazy.
bamabox is offline
post #3 of 14 Old 03-24-2018, 03:04 PM Thread Starter
Rears are 275/60 15s on 10" welds.
with a 410 gear.
I am not sure on HP never dynoed the car.
I am hitting it with 125hp shot on a WOT switch.
I know a slick and an auto would make life easier but I usually make things harder on my self.
Any suggestions on stiff wall slicks and sizes?
11.71 @ 116mph
post #4 of 14 Old 03-24-2018, 03:16 PM Thread Starter
HP calculator puts the power between 275 and 300hp, based on weight ET and MPH.
11.71 @ 116mph
post #5 of 14 Old 03-25-2018, 07:41 AM
bamabox's Avatar
You canít go wrong with the Hoosier part #18115. 26.0/ 8.5x15. They call it a 8.5 but itís a 9Ē tread. Stiffwall. I run it with no tubes and on a 10Ē wheel. Mine was a stick car as well, T56 with 5th and 6th removed, and launched at 6K. Awesome tire, not leakers, and very good for dialing in just the right amount of wheel spin on launch with tire pressure adjustments. This winter Iím putting in a C4 to bracket race so we shall see if they work well with the auto.
bamabox is offline
post #6 of 14 Old 03-26-2018, 01:02 PM Thread Starter
I will see about getting those tires, a 26" tire might help with with the reduced height and give the gears more advantage. With the the 275/60 tire i am only turning 5000 rpms at the light.
11.71 @ 116mph
post #7 of 14 Old 03-27-2018, 03:06 PM
Curious if you are granny shifting or powershifting? Nice 60 ft!!
69.5 Maverick, 480 RWHP 363 NA, Faceplated TKO 600, 4.30 gears, 9", E70-14 Whitewalls. "Stock Appearing" Sleeper. 1.72, 11.49 @ 124.87
tbirdz12 is offline
post #8 of 14 Old 03-28-2018, 11:10 AM Thread Starter
I have been still learning the the new trans so its 50/50 power vs granny shifting. I just put in a Pro 5.0 shifter and and Hurst handle to help grab 3rd better. Next trip out will be working on hitting those power shifts each run.
11.71 @ 116mph
post #9 of 14 Old 03-28-2018, 05:13 PM
stang93mustang's Avatar
dont forget a driveshaft loop if using slicks
I'm not SAYING, I'M JUST SAYING!!!!
93 LX stroked 460, TH400 with 9" 3.89 spool. Adjustable control arms, coilovers. Alot of good stuff!
This year winter project......new rear suspension!
http://youtu.be/5VJPoOuZ2mk?hd=1
stang93mustang is offline
post #10 of 14 Old 03-30-2018, 09:56 AM Thread Starter
Already have one installed.
11.71 @ 116mph
post #11 of 14 Old 03-31-2018, 10:00 AM
AlexLTDLX's Avatar
x2 on this tire. I run it too, on an 8" rim. Best 60' is 1.41. Typical is 1.45-1.46. I'm at 3,500 lbs.
AlexLTDLX
AlexLTDLX is offline
post #12 of 14 Old 03-31-2018, 10:20 AM Thread Starter
Are you running a tube with them?
11.71 @ 116mph
post #13 of 14 Old 03-31-2018, 11:28 AM
AlexLTDLX's Avatar
No. I run megabite Jr lowers at the 135 setting (lower hole).
AlexLTDLX
post #14 of 14 Old 03-31-2018, 01:13 PM Thread Starter
When I get the 26" tires I will also be able to set my Megabite JRs in that hole as well.
11.71 @ 116mph
Vacuum 2ndary Canister Check Ball Help Skidd 5.0/5.8 Engine Tech 1 01-14-2016 12:44 PM
MC Machine Dash, Check Engine Light Question... turboLXstang General Mustang Tech 0 08-09-2015 02:12 AM
cycle suspension to check for bind 79f150 General Mustang Tech 2 06-04-2015 07:25 PM
Check engine light with after market Cluster. Blackfive0 General Mustang Tech 5 03-03-2015 01:57 PM
P2v check with a Mexican block Fxblflyr 5.0/5.8 Engine Tech 2 11-15-2014 09:39 PM
