427 stroker what will it run in the 1/4. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 04-07-2017, 01:47 AM Thread Starter
autopart101's Avatar
In my 93 LX hatch. Just had my small bore 427 dyno at 457 rwhp 446 TQ. Car is full weigh a/c p/s. 3.73 gear 26 inch tire MT drag radials. TKO 600 Trans. I hope low 11s.
autopart101 is offline
post #2 of 10 Old 04-07-2017, 05:22 AM
1995gtCPE's Avatar
Trader Feedback: (34)
Where did you dyno at? Mustang or Dynojet? Know the exact weight of the car?
1995gtCPE is offline
post #3 of 10 Old 04-07-2017, 05:45 AM Thread Starter
Dynojet numbers. Full weight 93.
post #4 of 10 Old 04-07-2017, 01:02 PM
Project Reef Blue's Avatar
Low 11s should be a piece of cake
Stock Block 408", TFS 11R 205, TFS EFI Carb R Intake, XFI 236HR, Tweecer, Faceplated TKO 500
10.49 @ 130mph
Project Reef Blue is offline
post #5 of 10 Old 04-09-2017, 09:57 AM
Low 11's should not be a problem. Your biggest issue will be getting traction with the TKO and drag radials. It takes a lot of trial and error to get them to 60 ft with the 5 speed.
93 Cobra, Dart 408, Holley efi, and a 4r70w.
1/8th 6.46 @ 106.5 mph 3600lb race weight
boosted93cobra2 is offline
post #6 of 10 Old 05-08-2017, 02:32 PM Thread Starter
ran 8.0s with 2.20 60 foot times at 95-96 with 2600 DA day. next week going to idel out of the hole. If I hook and have a better air day might see 7.0s. not bad for a 100% stock weight car A/C p/S.
post #7 of 10 Old 05-09-2017, 08:44 AM
88 orangepeel notch's Avatar
I'd switch to a full slick, just for the fact it's just that much easier to get a car to hook at your power level and being manual tranny
That first 60 ft is the most important thing to fast times.
Good luck
88 orangepeel notch is offline
post #8 of 10 Old 05-09-2017, 09:06 AM Thread Starter
Good luck
going to get slicks and extra wheels to go with it. The DR low 60s must be an art.
post #9 of 10 Old 05-09-2017, 12:20 PM
Trader Feedback: (57)
At that mph you will need to cut 1.5X 60 foot to run 7.0's..If you finesse the car out of the hole with those tires you should be able to cut a 1.7X and run some 7.30's
1. Woman
2. Dyno
3. Dragstrip
sradtodrag is offline
post #10 of 10 Old 05-09-2017, 02:17 PM
Drag radials with a clutch is easier than you might think, it's all in being able to dial in the clutch.
Grant
ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!!!
weenburner is offline
Bias plies vs. radials on a foxbody mustang, or Casey's Ghetto Tire Comparison (long) aurdraco Road Racing/Auto X 3 07-19-2016 04:22 PM
Sn95 4.3L v6 stroker. Would F150 ECU run better? marcajustice General Mustang Tech 0 04-05-2016 08:29 AM
For Sale Boss 351w block, and 427 stroker kit 95MUSTGT Windsor Engine Parts 9 02-14-2014 04:50 PM
For Sale Teksid 5.0 stroker shortblock, new never run LS1_ETR Modular Engine Parts 2 11-27-2013 08:53 PM
For Sale Teksid 5.0 stroker shortblock, new never run LS1_ETR Modular Engine Parts 2 11-19-2013 08:17 PM
