9" pinion bearing driver - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-23-2017, 01:01 PM Thread Starter
Anybody know where I could purchase a 9" pinion bearing driver for use with a hydraulic press? I cant seem to find ANYTHING! I'm sure I could just use temperature differential to get the bearing on or pay somebody to do it but this wont be my last gear change and it would be nice to have the proper tool.
Fast351svo is offline
post #2 of 8 Old 02-23-2017, 03:18 PM
Saleen414's Avatar
I have always used a hammer and a punch with the pinion supported properly. A little WD40 or other light oil helps the bearing press onto the pinion gear. Have done it countless times this way.
26 X 8.5 Hoosier
Saleen414 is offline
post #3 of 8 Old 02-23-2017, 05:11 PM
Do you think DOM tubing with the proper ID and wall thickness would do the trick for you? That's what we use for pushing a lot of bearings at our business although not for 9'' pinions. Some of the jobs do use the freezer/oven method due to interference fit.
2 step is offline
post #4 of 8 Old 02-23-2017, 05:48 PM Thread Starter
I may have to go one of those routes. Its hard to believe I cant' find anybody that sells a tool for the pinion bearing...I just want to use my new press! At least ill get to use it on the S trac.
post #5 of 8 Old 02-23-2017, 07:21 PM
Yep, with you on that. I wish I had a good 5 ton press in my home garage.
2 step is offline
post #6 of 8 Old 02-24-2017, 11:13 PM
I'm not aware of a special tool. I've always used a hot plate, oven, or anything (other than open flame) to get the bearing warm, and then it just drops right on. To remove one, you need a bearing separator. And that tool comes in handy for more than splitting bearings off of shafts. Should be a must-have tool for a press in a shop.
https://www.amazon.com/CTA-Tools-806.../dp/B005OH0KA4
'92GT, 427" and '93 "LXVO" coupe
toddturbo is offline
post #7 of 8 Old 02-25-2017, 06:03 PM
An OTC splitter would be the preferred one. Much better handling. Specially if you want to reuse the bearing without buggering it up.
2 step is offline
post #8 of 8 Old 02-26-2017, 04:18 PM
When I press them on my 8.8 pinion I cut the cage off the old bearing place it on my separator with the new bearing on top and press the pinion on.
1987 Coupe: Stock 5.0, T5, 4.10s and a spool
russ3747 is offline
Strange HyTuff Race axle/spool/c clip elim install bamabox Drag Racing 0 04-01-2016 01:51 PM
Toasted thrust bearing and thrust face squarness? smith772 5.0/5.8 Engine Tech 7 01-16-2015 06:12 PM
Replacing pinion seal w/o dropping IRS carrier? DuffManRHA General Mustang Tech 8 09-25-2014 03:36 PM
Help! Pilot bearing removal gone south! BigPimpHustler 94/95 Tech 13 12-04-2001 06:42 PM
Please help: pinion bearing preload. maus 5.0/5.8 Engine Tech 8 11-30-2001 02:06 PM
