2016 Mustang GT auto with 3:55 rear track times... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-26-2016, 02:57 AM Thread Starter
Today I ran my car at Raceway Park in Old bridge N.J on a very hot day and was pleased with my results..
1st pass I held the traction switch up for 6 seconds until advance trac was totally disabled, put the trans in S and also put the car in track mode and steering in sport, I did a small burnout using the line lock and staged the car,I held the brake and got the rpms up to 1500, mashed the throttle on the 3rd yellow and cut a nice light, I hit a 2.01 60' and thats when all went to hell, the car didnt shift and seemed to bounce off the limiter which caused the car to fall flat on its face, I just coasted up to the finish at a blistering 22 seconds at 55mph. Maybe someone can tell me what I did wrong?
2nd pass I didnt hold the traction switch or even touch it, all I did was put the car in track mode and the shifter in D, I didnt even use the line lock, I did a quick power brake to clean off the stock tires and staged the car, I raised the rpms up to 1500 again by holding the brake and applying throttle, on the third yellow I stomped the pedal to the floor, cut another good light and just hoped it would shift and not embarrass me again, this time it shifted properly and I just held on and kept her centered, I was rewarded with a very respectable 2.01 60' 12.85et at 110mph on a hot and humid day, elevation was 1584 so corrected time at sea level would be 12.628 at 112.20 if you believe the drag times calculator.
3rd and final pass I was going to do everything the same as run 2 except that I would put the gear selector in S. I hit a 2.02 60' and ran 12.846 at 110.46 . The corrected times for 1325 elevation would be 12.663 at 112.078. I only posted the corrected numbers because some people and forums require a corrected time due to running in lets say Colorado and then running any of the tracks in NJ there would be a half a second difference using the same car.
jelsis is offline
post #2 of 5 Old 05-26-2016, 06:57 AM
TomR's Avatar
Did you bump the shift paddle button on the first run and lock it in 1st?
TomR is offline
post #3 of 5 Old 05-26-2016, 08:52 AM
88 orangepeel notch's Avatar
Either way, skipping that first flubbed pass, very impressive. Congrats
Fresh 306, BBK fender mount CAI, 75mm MAF, 70mm throttle, Typhoon intake, Letter cam, ported/polished E7's, BBK equal length shortys, Full exhaust with Flows. T5 swap, 3:55's
Dyno'd 300/316
Best ET 12.4 @ 108, 1.66 60ft on stock suspension
Track scale - 2745 lbs
88 orangepeel notch is offline
post #4 of 5 Old 05-26-2016, 09:35 AM Thread Starter
Thanks, the third and final run I was up against a s550 Eco boost mustang which had a tune and some other things done, I had told the driver what happened on my first pass and he said he had something similar happen a few weeks back where his car went dumb and didn't shift which blew up his trans 2 or 3 gear. He returned his car back to stock n was lucky that ford didn't detect the car had been tuned. All in all it was a good evening.
jelsis is offline
post #5 of 5 Old 06-04-2016, 12:04 AM
AlexLTDLX's Avatar
Not buying the corrected times (they're always optimistic on my car - I need mineshaft air to hit them; never mind the high-altitude guys who never - and I mean never, in my 25 years of racing - run the number at sea level), but 110 mph in a stock, almost 4,000 lb, $30k car is amazing.
Do you think sticky tires would bring down your 60'? Were you easy on the throttle to stay out of spin? A converter and sticky tires could get you dangerously close to 11's.
AlexLTDLX
AlexLTDLX is offline
MVP Track Time 2016 Southeastern Track Events (Come Drive With Us) Feffman Southeast 2 05-11-2016 07:17 AM
For Sale 1997 Mustang GT with IRS modularmustang Mustangs For Sale/Wanted, 1994-1998 2 05-29-2014 08:18 PM
For Sale 11 second Supercharged 1998 Mustang GT Street Strip Car, 460 RWHP sn4bwc Mustangs For Sale/Wanted, 1994-1998 3 10-02-2011 06:23 PM
For Sale 1989 Mustang LX 5.0L FULLY BUILT/RESTORED/Custom Dash! BOSSGT Mustangs For Sale/Wanted, 1987-1993 1 05-29-2011 07:43 AM
