8.8 with 9" housing ends brake disc offset? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 04-20-2016, 05:10 PM Thread Starter
Caprimaniac's Avatar
Well, I havent figured this out yet... Would really like some input.
Stuffing Strange axles into the 8.8 Explorer housing, shortening and "late style big" 9" hosings welded to the tubes, eleminating c-Clips and using the 9" bearings/ retainers.
I was going to reuse the Explorer disc brakes for the time being. However- Dimension F on the axle order form- distance from Wheel (brake disc) flange on axles to flange of the housing ends.
I have tried to look the distance up by searching, but no Luck. Brake kits are listed With "offset" 2.5", 3.something" etc.
Tonight I went to my shop and did my best to measure the distance on the Esplorer axle. I came up With, quite exact 55mm or 2.165".
Is this correct distance F?
And BTW: What aftermarket disc kits will suit this offset?
Regards
RuneS
Caprimaniac is offline
post #2 of 14 Old 04-20-2016, 05:18 PM
GilroyRacing's Avatar
Trader Feedback: (111)
Do you have the large bearing ends welded on already?
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th [email protected] 1/4
302 1.59 60' [email protected] [email protected]
GilroyRacing is offline
post #3 of 14 Old 04-21-2016, 08:25 AM
danh9250's Avatar
Trader Feedback: (62)
Strange uses a 2.5" axle offset for mustangs
1993 coupe 5.0 5 speed
1986 coupe 5.0 auto
2011 gt sterling silver auto
88lx hatch regatta blue. Dart427 twin precision 7675s t-56 3300lb street drivin
[email protected] through tailpipes
danh9250 is online now
post #4 of 14 Old 04-23-2016, 10:25 AM
faststang90's Avatar
here is my parts when
here is my parts when they did my 8.8 with 9 inch ends on my ranger.
1994 ranger 347 c4 4:30 gears best pass [email protected]
faststang90 is offline
post #5 of 14 Old 04-28-2016, 12:22 PM Thread Starter
Hiya
No, not welded on, haven't got the parts yet.
Faststang; I was hopipng specs on the Moser axles were included in the file!
And yes, I know alot of the aftermarket brake kits has 2.5" offset, but i wanted to retain the Explorer brake setup for the time being, and my question is.... are they 2.5" offset as well?
This 2.5" offset.... Is it "F" or "B"- Dimension, or both or none in enclosed pdf???
Hopefully PDF sticks on here...)
post #6 of 14 Old 04-28-2016, 01:37 PM
the shop that done mine is Pyle brothers in Baytown Texas 281 421 5878. I know the 8.8 stuff will not work on the 9 inch ends
post #7 of 14 Old 04-28-2016, 01:54 PM
also the rangers 8.8 is what they call a trucks 8.8 and it is not the same size as the mustangs 8.8. I would think it was the same on the Explorer's 8.8
post #8 of 14 Old 04-28-2016, 02:48 PM
The cast centersection of the Ranger 8.8 is the same as the Explorer and F150 8.8, but the Ranger 8.8 has axle tubes that neck down in the middle and use the small 1.40" dia passenger car axle bearings and a smaller bolt pattern on the end where the brakes bolt on. Explorer ends use the larger F150 bearing and the same bolt pattern for the brakes as a "Torino" style 9" end (larger center hole though).
Grant
ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!!!
weenburner is offline
post #9 of 14 Old 04-28-2016, 03:18 PM
If you decide to go with the small bearing 9" ends, I have a set of north race car brackets.
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th 10.6[email protected] 1/4
post #10 of 14 Old 05-01-2016, 04:34 PM
2.5 offset and you can use GT or cobra brakes, and it will leave things wide open for brake choices if you want to upgrade.
Street car with a 5 speed
427ci SBF -- 9.86 at 136mph
http://youtu.be/2GKQ2xpZraU
Drag Week 2013 SR/SB/NA Winner
Doc's Notch is offline
post #11 of 14 Old 05-03-2016, 05:11 PM Thread Starter
Thank you for all answers....
Going With Torino ends (large late style).
And yes, Indeed I know alot of the aftermarket use 2.5" offset.
My question was; what Dimension do I Write Down on the Strange axle form.... I have not reached a conlcusion on that yet.
As I have tried to say; With the equipment at hand, I figured the F- Dimension on the order form above, on a untouched Explorer 8.8 to approximately 55mm. Is this Dimension correct?
(Not easy to measure when brake Shields, shoes ++ of brake Equipment installed)
Reason why I want to use Stock Explorer Dimension is to use the brakes from the Explorer (which has the late big bearing pattern).
post #12 of 14 Old 05-04-2016, 03:12 PM
2.5" is the number, best bet is to call strange and they can help you with questions on filling out the form.
post #13 of 14 Old 05-05-2016, 10:43 AM Thread Starter
Thank you, Doc.
My measuring- did it again last night- still 55mm...... 2.5" is 63mm.
Something just don't add up. I will order them 2.5" and see what happens. If bad luck, I will have to get a nice set of aftermarket brakes.....
post #14 of 14 Old 05-05-2016, 10:53 AM Thread Starter
Let me add; measured with flanges w/ bearings/ brake shields/ brackets/ and handbrake shoes cut of the tube and put on the axle. Great room for errors!
I will update as soon as axles are in. If member it by then....
For Sale Built, welded, braced, 9" ends...8.8 rear & axles Shifter Drivetrain Parts 0 03-22-2016 07:07 PM
Want To Buy Want To Buy: Rear Disc Brakes for 9" Housing Ends CMac455 Suspension 1 06-06-2014 10:18 AM
For Sale Bare 8.8 housing with 9" ends jarryd2018 Drivetrain Parts 25 08-18-2013 01:43 PM
For Sale Hawk Brake Pads FREE SHIPPING [email protected] Suspension 6 12-02-2011 12:35 PM
For Sale $300 Complete 8.8 Rear 3.73 Disc brake set-up.. bolt in. OutLawSE Drivetrain Parts 2 08-24-2011 07:51 AM
