12-150 coilovers what where to set adjuster height - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 04-02-2016, 06:19 PM Thread Starter
venom1997's Avatar
12-150 coilovers where should adjuster be at? Right now the way the pic is it will sit too low in front about inch under wheel well car weighs 3000lb Lakewood 90/10
venom1997 is offline
post #2 of 23 Old 04-03-2016, 10:07 AM
Jersey True Street Guy
mcj50's Avatar
Trader Feedback: (84)
With a 150 rate 12" may work but will be on the short side. 150 and 175 rate front springs are generally used at 14" on a fox.
mcj50 is offline
post #3 of 23 Old 04-03-2016, 10:35 AM Thread Starter
venom1997's Avatar
Should I take it up little higher on adjuster like an inch
post #4 of 23 Old 04-03-2016, 03:20 PM
dr59l's Avatar
Take it up higher 12/150 is Wat a lot guys including myself run an works perfectly without scrubbing the threads off like a 14" is known for
351w nitrous hydro roller c4 4.30s [email protected] all motor an still gaining. N20 times to come
dr59l is offline
post #5 of 23 Old 04-03-2016, 03:22 PM
dr59l's Avatar
dr59l is offline
post #6 of 23 Old 04-03-2016, 03:54 PM Thread Starter
venom1997's Avatar
Thanks man I'll take it up another inch or 1.5
post #7 of 23 Old 04-04-2016, 09:15 AM Thread Starter
venom1997's Avatar
Guys got this setup on this weekend for drag use when I push down on the nose of the car it's pretty stiff is it normal fox Lakewood 90/10 the spring is up about half way up on the adjuster so spring is preloaded but plenty of room In between before any coil bind I'm thinking coilovers are different than normal springs where car bounces up n down when you push nose down by hand
post #8 of 23 Old 04-04-2016, 10:47 AM
dr59l's Avatar
Mines same an works good
dr59l is offline
post #9 of 23 Old 04-04-2016, 11:00 AM Thread Starter
venom1997's Avatar
Ok the same as it doesn't Bounce when you push it down? I haven't drove it yet but I'm thinking when you throttle it is when it lifts?
post #10 of 23 Old 04-04-2016, 12:20 PM Thread Starter
venom1997's Avatar
I can't wait to hit the strip
post #11 of 23 Old 04-04-2016, 05:00 PM
Trader Feedback: (25)
that is the game with the Lakewood 90/10s.they will extend easily but only go in/push down at 10% of the rate of extension. So naturally they will be harder to push down. That is why I took mine off for some different struts that move more freely.
79f150 is offline
post #12 of 23 Old 04-04-2016, 05:14 PM Thread Starter
venom1997's Avatar
Ok thank you so much
post #13 of 23 Old 04-04-2016, 07:08 PM
Personally I like the 12''x 150 that Dr recommended for the same reasons with a Strange strut. And don't need the chains. But a gas filled Lakewood can handle 12'' inch or 14'' with ease. Lakewood's have a longer stroke.
cocomojak is offline
post #14 of 23 Old 04-04-2016, 10:32 PM Thread Starter
venom1997's Avatar
Raised it the 1.5 inches up the adjuster and did the 50/50 lake woods in rear boy when you tap the throttle it pops running 275/60 Hoosiers I'll have to see what it 60s
post #15 of 23 Old 04-04-2016, 11:23 PM
keep us posted
79f150 is offline
post #16 of 23 Old 04-05-2016, 12:04 AM Thread Starter
venom1997's Avatar
Will do thanks for your help guys
post #17 of 23 Old 04-05-2016, 03:22 PM
dr59l's Avatar
Lose limiters might come in handy once I flip the switch on that induction solutions kit cocomojak lol
dr59l is offline
post #18 of 23 Old 04-05-2016, 05:42 PM
Yep, you'll be the first one to find out.
post #19 of 23 Old 04-05-2016, 06:38 PM Thread Starter
venom1997's Avatar
When do the limiters come in handy?
post #20 of 23 Old 04-05-2016, 08:27 PM
dr59l's Avatar
Honestly only if ur car has a wheelie issue. It only pulls em a foot now but on the jug it may get hairy. I'm jus start small at 200 an go from there
dr59l is offline
post #21 of 23 Old 04-06-2016, 08:37 PM Thread Starter
venom1997's Avatar
Did a soft launch on the street and the front pops but the driver side a lot more is that normal
post #22 of 23 Old 04-06-2016, 11:20 PM
unfortunately it is the norm for Fox body cars without anti roll bars (ARB). they mount to the rear axle and the frame forcing the frame to lift up equally.here is a link to a post that I put a couple videos into.Post # 7 in the thread. Its the same car before and after installing an ARB.https://forums.corral.net/forums/gene...-your-fox.html
79f150 is offline
post #23 of 23 Old 04-21-2016, 09:01 PM
nick5oh's Avatar
I believe I set my adjuster so that I had a 1/2" less ride height than the rear measured from the ground to the top center of the wheel well. If i remember correctly it was about 25.5" or 26". 12" 150lb springs on strange single adjustables. I love them. Only thing bothering me is I have a weird clunk noise when I push the front end down by hand. It clunks when the travel bottoms when pushing down by hand. Took a strut/spring setup out on one side, took a look, couldn't find anything noticeable, put back together, still noise. Still can't figure it out.
Anyways a little lower in the front than the rear will work good. Strange are way better than the lakewoods but a 90/10 Lakewood works good as well. They like to wheelie! I had better 60' times when I put a DA shock in the rear with the 90/10 up front than I did with the 90/10 and 50/50 combo, even better now with the same DA rear shock and a strange single up front.
nick5oh is offline
Installing MM K-member A-arms Coilovers on my 92 MFE Road Racing/Auto X 85 11-26-2016 09:40 PM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
Simple coilover/suspension installation instructions (ST coilovers) neema S-197 Mustang GT (2011-2014) 0 09-25-2011 02:53 AM
what height do you set your gt40 valve springs to dirty2003 5.0/5.8 Engine Tech 8 09-16-2011 05:10 AM
tuning new set up allenpeake Turbochargers 7 11-30-2010 07:30 PM
