8 to 10 point conversion cage - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-14-2016, 03:00 PM Thread Starter
sprayed347's Avatar
Who's 8 to 10 point conversion cage are you guys using ? Does the s&w or comp engineering one go through the speaker holes I don't want them to come in front of the dash.
sprayed347 is offline
post #2 of 7 Old 02-14-2016, 04:34 PM
GilroyRacing's Avatar
Trader Feedback: (111)
Call S&W, they will hook you up with all the right parts.
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th [email protected] 1/4
302 1.59 60' [email protected] [email protected]
GilroyRacing is offline
post #3 of 7 Old 02-14-2016, 05:35 PM
ZSR
ZSR's Avatar
I like the Wolfe cages and would try them first if I wanted a mail order kit/conversion. If I remember right, they do offer the 8-to-10
ZSR is offline
post #4 of 7 Old 02-15-2016, 07:38 AM
SRTthis798's Avatar
Trader Feedback: (15)
to do it right...
cut out the bar and start over
bars need to be 1.75" inch tube
cage is 1.625"
DT Racing and Fabrication
Crew Chief
Roche Racing engines Billet headed windsor! BMF on 275s!
my car-88lx- 408" stock block gangster!!!
SRTthis798 is offline
post #5 of 7 Old 02-15-2016, 09:51 AM
I agree with that
91 Fox
post #6 of 7 Old 02-15-2016, 12:20 PM Thread Starter
sprayed347's Avatar
mine was done by Jeffers pro cars here in Missouri. will need to check the tubing size they used.will check it tonight thanks for the info.
big cox racing
post #7 of 7 Old 02-16-2016, 02:54 PM
Originally Posted by SRTthis798 View Post
to do it right...
cage is 1.625"
I agree with this...I went through this same thing about a year ago. I thought about trying to convert my bar to a cage to save money, but I knew I wouldn't be happy with it in the long run. I finally removed the 6-point and started over with a chromoly cage and I am so glad that I did. Doing it right the first time is extremely important when it comes to your chassis. It is costly and time consuming and you won't want to have to revisit it anytime soon.
1995 Mustang GT Coupe
333" SBF | Vortech YSI | AOD | Holley EFI
1.24 60' | [email protected] | [email protected]
95StangRC is offline
Wolfe Race Craft 8.50 Cert 4130 Cromoly Cage Install wgregan General Mustang Tech 16 03-21-2013 05:14 PM
Guidance on new Notch cage setup 89BlackGtVert Member Build-Up Projects 10 01-29-2013 11:42 AM
Corbeau seats fx1 pro with 6 point cage blacktop General Mustang Tech 0 04-04-2012 06:26 PM
Help me pick a roll cage/ roll bar for my street/ strip Fox FiveLiterFox Drag Racing 24 04-03-2012 07:51 PM
MAF conversion, won't idle, suggestions? AlanGT350 5.0/5.8 Engine Tech 31 06-13-2011 12:25 AM
