89 5.0 vs camaro - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 04-19-2012, 01:38 AM Thread Starter
89 5.0 vs camaro
Would I be able to beat a ls1 camaro or new ss with this setup without a 100 or with my 89 5.0 ?
Ported Gt40p heads
E303 cam or b303
bbk Cold air intake
Ported Gt40 intake
Ud pulleys
Delete smog
1.6 rr.
Bbk shorties unequal length Headers
Cc springs
3:73 gears
70mm tb
75mm ma
tm rebuild
Bama custom tune
24# injectors
Dual 12" Electric fans
Harden pushrods
100 shot
Playdoh61 is offline
post #2 of 4 Old 04-19-2012, 11:38 AM
2 cam sam's Avatar
Should be at 350 rwhp and alot lighter car. You should whoop up on some stock units.
1993 Cobra
2008 Gt stock
1983 Mustang L 351 w
2 cam sam is offline
post #3 of 4 Old 04-21-2012, 10:46 AM
Venom351_R's Avatar
With the 100 shot you should have no issues. NA might be a bit harder. Those LS1 engines were under rated from chevy a lot of stock LS1's were pulling in the range of 320 RWHP
1994 SVT Cobra #42 of 5009/ 95 Cobra R drivetrain
Performance- FTI TFS Custom CNC Ported 234HR High Ports /Edelbrock Victor 5.8/FTI Camshaft/Accufab 75MM TB/ PMAS 95MM Velocity Meter/Tremec 3550
Venom351_R is offline
post #4 of 4 Old 04-21-2012, 11:13 AM
Deer Assassin's Avatar
yes
88' coupe 387 ci poor boy stroker eagle 3.85 crank stock 351 rods (5.956) stock 5.0 pistons (4.00) c-4 built by PTC, 4.30 8.8 rear end 1.49 60 foot 6.99 1/8 mile 97.18 Mark Sullens E-85 carb UPR suspension
Deer Assassin is offline
1989 5.0 vs camaro? Playdoh61 5.0/5.8 Engine Tech 8 04-21-2012 12:09 AM
gt40y crate 5.0 vs stock 5.8 roller, and help with cam selection v8only 5.0/5.8 Engine Tech 7 02-16-2012 10:35 PM
Is an A3m ecu the same as an A9L? Bigindian 5.0/5.8 Engine Tech 5 11-13-2011 12:06 AM
For Sale 88 Bronoco II 4x4 with 5.0 HO swap guns_not_groceries Other Fords and Trades 1 10-30-2011 07:12 PM
5.0 Mustang vs LS2 Vette vs LS3 Vette 00whiteGTvert S-197 Mustang GT (2011-2014) 41 01-21-2011 09:08 AM
