3.73 to 4.10 or 4.30 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-02-2012, 06:28 PM Thread Starter
1QuickS2's Avatar
I have a 308 with trickflow heads, eldebrock intakes and so on, right now Im running a 26 inch tall tire in the back with 3.73 gears, would a switch to 4.10 or 30's be worth the switch?
1996 SVT Cobra, CAI, Long tubes, x pipe, pro 5.0, Alum D/S, 4.30's
89GT 308 Built and Tuned by F&F Performance Sold
95 GT Sold
97 V6 Sold
1QuickS2 is offline
post #2 of 8 Old 02-02-2012, 06:41 PM
gonemad's Avatar
5 speed or auto ? cam? which edelbrock...s....?, exhaust? suspension? intended use of car? track or street if both where u want to perform best? which trick flows? what kinda power does car make? what rpm? Slicks? drag radial? street tire?
More to it than what listed lol we can help just need some info bro.
88 stock bottom end coupe. On3 70mm trick flow 170s home ported explorer intake with c4 on 14lbs [email protected]
04 CO lots of bolt ons [email protected] n/a, [email protected] with 150 shot.
gonemad is offline
post #3 of 8 Old 02-02-2012, 06:46 PM
3.73's with a 26" tire work well, but as Gonemad stated it depends on alot of things.
It's not the size of your shop, it's what comes out of it that counts.
mustangmatt8693 is offline
post #4 of 8 Old 02-02-2012, 08:51 PM Thread Starter
1QuickS2's Avatar
Haha yeah sorry about that, It was in my sig and I forgot that I had changed it. Its a 308 long rod engine. 10.5 to 1 , custom grind cam, not sure of the specs lost the cam card. trickflow 170's ported to 180's. performer 2 intakes, both ported, 30lb injectors, 75mm tb, 76mm mass air flow, 1 5/8 long tube headers, 2.5 inch o/r h pipe hooker maxflow mufflers into dumps. no ac, no smog. t-5, mainly street this year, mostly track next year. I perfer the car to perform best on the track. Stock suspesnsion other than lowering springs and sub frame connectors. Power im not sure, haven't had it on the dyno, it really needs a tune. I assume around 300-320 rwhp the way it is. 6200-6500 rpm engine. Nitto 555r DR.
95 GT Sold
97 V6 Sold
1QuickS2 is offline
post #5 of 8 Old 02-02-2012, 09:05 PM
If it's a stock t5 I would go 4.10's with the 26's you'll want to shift about 4-5 hundred rpm above peak power and trap a little over peak as well. If your using a shift light program it to come on about 600 rpm before you want to shift. For the simple reason by the time you see the light and actually push clutch and pull shifter you'll be over your rpm. I learned this from mr Hemminger if you can program shift points for every gear you can get closer with the light in the higher gears because the shifts will not come as fast.
-337 ci 10.5comp, fogger,out/box afr185s,supervic
-tko600 [email protected] 1.35 60ft
-clutchless [email protected] 1.32 60ft best 1.22
Hauling ass with small stuff on a 26x10 tire
337stroker is offline
post #6 of 8 Old 02-02-2012, 10:50 PM
Stephen Johnson's Avatar
thats why you put a chip in there or program the light to come on right before you need it to shift..... I've been doin it for years in both cars..
SS/D 427 Ford Fairlane NHRA-IHRA (Ex- Van Cleve) [email protected]
SS/D IHRA Record Holder
SS/E NHRA Record Holder 9.49 @ 139mph
1985 mustang Daily Driven N/A 331 10.78 at 123mph
Stephen Johnson is offline
post #7 of 8 Old 02-06-2012, 05:48 PM
going from 3.73's to 4.10's raises the rpm at a given speed by around 200 rpm. it will wind up quicker..but will spin more(less traction)taking off. 3.73's are good for a daily driver, but the 4.10's will work too. you'll be able to take off from the light feeling like you have a bigger motor(more torque multiplication in lower gears). with a 4.30's, you can get er goin as long as you have some sticky tires. I use to leave my boss's viper at the light till 60 mph! it was a 88 GT 5sp 4.30's American racer G-60 DOT dirt tires and usual bolt-ons.
90 coupe, 302,9.7 comp,scat rods, ported windsor sr.'s(286 [email protected]" 2.05/1.60),tfs stage 3 cam,
funnel web, 750dp,c4/4000,4.30 gears, aeromotive 140 pump-motor/holley red for nitrous, 16 gal. cell, 2 stage nitrous,M/T 28x9 et drag,5" cowl hood.
tim harris is offline
post #8 of 8 Old 02-06-2012, 06:43 PM
i love my 4.30 as long as im not on the highway to mutch
[email protected] on a 275-50-15 drag radial tru a t5 1.64 60ft first time out
im gona try 4.10 to probably this year
lov2xlr8 is offline
For Sale fms 4.10, fms 3.73, and Valeo k/c clutch silverstang55 Drivetrain Parts 5 11-06-2011 10:57 AM
28's w/ 4.10 or 26's w/ 3.73 daves80capri Wheels and Tires 2 08-10-2011 08:33 PM
28's with 4.10 or 26's with 3.73 daves80capri General Mustang Tech 1 07-27-2011 11:49 PM
Want To Trade Anyone wanna trade frpp 3.73 for 4.10 or higher??? 03SonicBlue_GT Drivetrain Parts 3 05-09-2011 10:28 PM
