17" Radial Guys Suspension? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 12-31-2011, 06:08 PM Thread Starter
Meangrn92GT's Avatar
Trader Feedback: (62)
What are you guys using who run 17" radials? I'm sure 98% will be done on MT brand but post more specifics on your setup. Able to leave off transbrake/two step with any big wheel setups?
-Dave
1992 Mustang GT
Meangrn92GT is offline
post #2 of 13 Old 01-09-2012, 12:00 PM
Trader Feedback: (26)
With a stick car and nitrous I can't leave the line on the nitrous. I also have to use a lot of clutch control. I prefer 15" radials. I have teamz rear suspension. I can hook a 17" nitto 555r and lift the front tires but track prep has to be perfect. Once the track goes away I'm chasing my tail on them though. I will be running 15" Mickey Thompson in true street this rear in the NMCA west. In PSCA I will stick with my slicks.
Mark Thompson PSCA Mustang Maddness 37
84 Mustang GT, 408 super Vic intake, high port heads, pro system 1000cfm carb, inductions solutions sledge hammer nitrous system, glide. Full TeamZ suspension.
FordFreak300 is offline
post #3 of 13 Old 01-09-2012, 03:04 PM
SRTthis798's Avatar
Trader Feedback: (15)
those are jokes for a drag radial
DT Racing and Fabrication
Crew Chief
Roche Racing engines Billet headed windsor! in da 6's with the chutes out before the 1000'
my car-88lx- 408" stock block gangster!!!
SRTthis798 is online now
post #4 of 13 Old 01-09-2012, 04:30 PM
I know, but I can get them to hook a lot and are really just my street tires. Most 17" radials are a joke. I have ran on most of them. The 555Rs have the longest life for street driving. The important thing is I gave the OP some sort of answer to his question even though my car is different than his. Hopefully more will chime in and help him out.
post #5 of 13 Old 01-09-2012, 04:49 PM
Stopsign32v's Avatar
555R is the perfect street tire IMO.
03 Mach 1 5 speed gears, RAI, catback, shifter
Stopsign32v is offline
post #6 of 13 Old 01-09-2012, 06:33 PM
I couldnt agree more
post #7 of 13 Old 01-15-2012, 07:02 PM Thread Starter
It's all good, I would really want to use 15" radials but I'm still digging on what wheels will clear rear Cobra brakes. Not many radial choices in radial sizes in 16" wheels so I figured I'd play the 17" game.
I had a set of Baseline Uppers and sold them, now I still have to buy some uppers. Whoops
-Dave
1992 Mustang GT
post #8 of 13 Old 01-15-2012, 07:35 PM
front is D&D tubular k member and a arms, strange coil overs
rear is team z relocated uppers, team z double adj. lowers with sway bar. after market stock location sway bar, stock springs 1 coil cut out. strange adj. shocks in the rear. 275/50/17 with M&H drag radials runs a consist 1.44-1.48. 28x10.5x15 slick was a 1.33
leaving off the transbreak at 4200 rpms and 6 lbs of boost. i tried 8-10 lbs and it would just blow the tires off. i have pics of the car the car sits in the Drag suspension thread.
chevyguy15 is offline
post #9 of 13 Old 01-19-2012, 08:58 PM
Sounds slow
stangboy460 is offline
post #10 of 13 Old 01-20-2012, 03:44 AM
Originally Posted by stangboy460 View Post
Sounds slow
14's on a good day!
post #11 of 13 Old 01-23-2012, 06:42 PM
331merc's Avatar
I run 275/50/17 M&H drag radials on my Capri. They are only like 9" wide on my 9" wheel. Initial testing I have gone 1.37 to the 60' leaving off the trans brake @ 3800 rpm and 6# of boost. This is in my nose heavy 3700# race weight street car. I hope I can get into the 1.2 range. And I am pretty sure I will be able to with my new Team Z suspension and adjustable mounting points on the 9" housing.
I was using Strange shocks and struts, 12" coil overs up front, stock GT coil springs in the rear, Steeda upper control arms and UPR lower control arms. The control arms are the poly bushing style. The new Team Z stuff has rod ends on it.
I have found getting going quick on these "small tires" is suspension tuning AND power tuning. I can't leave with too much power or I kill the tires. Not enough and it leaves soft. But with a 1.37 after only about 12 passes on the new motor combo I was happy. More to come this year.
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
post #12 of 13 Old 01-24-2012, 05:25 PM
i have the same tire on my car, they hook and are nice down the road.
post #13 of 13 Old 01-24-2012, 05:28 PM
331merc's Avatar
I am impressed so far.
331merc is offline
Rear suspension questions. sam92lx Drag Racing 20 05-06-2012 03:08 PM
Want To Buy 17" Drag Radial Quick302Pony Rims Wheels and Tires 6 10-03-2011 08:57 AM
Hoosier Drag radial vs. MT drag radial racer2fast Drag Racing 18 08-07-2011 11:04 AM
anyone have experience with suspension kits? mysticcobradude GT & SOHC 10 11-28-2001 07:10 PM
Help me with my drag oriented suspension Billy Edwards General Mustang Tech 3 11-28-2001 11:02 AM
