Aerospace front brakes = crappy pedal feel??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 09-09-2008, 08:40 AM Thread Starter
Corral Charter Member
NO MANRZ's Avatar
I had better pedal feel with my stock brake setup up front.
Did the Pro Street setup up front with the vented rotors (not the drag setup) and the pedal damn near goes to the floor... just doesn't seem to have the stopping power I think it should have... am I missing something??? Do I need to upgrade my master cylinder because of the 4 piston calipers??? I have anywhere from 10-14" of vacuum and the pedal still feels like trash. My sphincter is in full pucker mode trying to slow down from a low 10 second pass at the track.
Anyone???
NO MANRZ is offline
post #2 of 14 Old 09-09-2008, 09:08 AM
Thriller8's Avatar
Yeah you should use a different master. Go with this one since you are running the Aerospace brakes.
http://www.jegs.com/p/Aerospace/751104/10002/-1
It will require you to change the mounting point on the pedal. I believe an inch or so you have to drill a hole. You need to change the ratio. I'm not sure off hand what it changes to...for some reason 6:1 or 7:1...is what I am thinking of.
X275 build in progress follow on Mustang Junkies.net
http://www.mustangjunkies.net/f9/project-dirty-red-444
Thriller8 is offline
post #3 of 14 Old 09-09-2008, 09:19 AM Thread Starter
NO MANRZ's Avatar
Oops, I forgot, I am running power brakes and want to keep it that way. I know there must be plenty of guys out there running power brakes with the Aerospace stuff...
2003 Mustang GT
NO MANRZ is offline
post #4 of 14 Old 09-09-2008, 09:22 AM
Thriller8's Avatar
Maybe with the stock master in there you aren't getting enpugh fluid. A bigger bore size on the master should help. I would think Aerospace has a master to use with power brakes as well.
If this is mainly a track car I would go with manual brakes.
post #5 of 14 Old 09-09-2008, 09:35 AM
Moderator
Jeff88coupe's Avatar
I switched to a 93 cobra m/c when I swapped to wilwood front and rear disk drag brakes. My pedal is like a rock...stays nice and solid when braking. You can also use a 95+ v6 or gt m/c also I believe. Do a search on disk brake master cylinders on here...you'll find all the info you need.
Xtreme 8.5" -Heads up 1/8th mile limited 8.5 class at Kilkare Dragway
Dedpedal Racing;Sponsered by
;Tuned by
Boss block Big bore 347/225 TFS HP's/SR/BW S476R/A2W/PG/FAST xfi on E85
5.33 at 134.9 on 26x8.5 in 1/8th @3380#
Jeff88coupe is offline
post #6 of 14 Old 09-09-2008, 09:51 AM Thread Starter
NO MANRZ's Avatar
I am still rear drum, but will probably go to rear disc over the winter... that might be the time to do the Cobra m/c since I'd need to upgrade from the stock m/c anyway, right???
2003 Mustang GT
NO MANRZ is offline
post #7 of 14 Old 09-09-2008, 09:52 AM Thread Starter
NO MANRZ's Avatar
Mainly street car, so manual brakes aren't an option, at least not for me, hehehe...
2003 Mustang GT
NO MANRZ is offline
post #8 of 14 Old 09-11-2008, 03:16 PM
Shifter's Avatar
Trader Feedback: (192)
Do the cobra MC, you'll be fine! When I did the 73mm caliper upgrade on my 92 the brakes felt like crap...then I did the cobra MC and the brakes feel awesome!
Shifter is offline
post #9 of 14 Old 09-11-2008, 06:05 PM
I have Aerospace front and rear brakes. I went with a 93 Cobra m/c and still needed to change the brake pedal ratio.
Good luck
Eric
89 GT Blown 392 [email protected] Run'in on Corn:cool Sold
98 Dodge Viper GTS Sold
86 GT Vert
paxtu22 is offline
post #10 of 14 Old 09-11-2008, 10:37 PM
VORTECD's Avatar
Stock power with the aerospace and drums on mine. I just changed the pads this summer. Been on there since '01. New pads were hard and not doing much until I did some stops with it. They improved much more after stopping from over 140 at the track. My pedal never goes to the floor. Did you try bleeding the system? Also try pumping the brakes on a stop. Mine seem to be better after I hit the brakes let up and hit them again.
'13 GT auto
VORTECD is offline
post #11 of 14 Old 09-12-2008, 04:07 AM
Moderator
eleanorfox's Avatar
Trader Feedback: (57)
whats so great about going manual brakes for a track car anyways?
eleanorfox is offline
post #12 of 14 Old 09-12-2008, 09:21 AM
Thriller8's Avatar
Most tracks cars have radical cams...they don't work well with power brakes.
post #13 of 14 Old 09-12-2008, 03:51 PM
Moderator
eleanorfox's Avatar
o because of the vacuum?
post #14 of 14 Old 09-12-2008, 05:19 PM
Thriller8's Avatar
yup.
