96 Cobra Drag setup - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-04-2008, 10:56 PM Thread Starter
96 Cobra Drag setup
I'm looking to setup a mild street/ aggressive strip type of suspension. I have a 96 GT that has been swapped with a DOHC 4.6. I would guesstimate the race weigh is around 3600lbs. I have a tubular k-member and a-arms already. Up front i am unsure of what spring to use. I was think a 14" 150# hypercoil with strange adjustable struts. In the rear i planned on using a UPR anti-Roll bar with a set of Eibach drag launch springs accompianed by a set of UPR pro-series double adjustable uppers with Southsides for lowers. Dampening the force's in the rear would be a set of strange adjustable shocks. Does anybody see anything wrong with this combo?
96 GT- Complete 4v swap, 4.10's
93 GT- Traded
97 F150-PI swapped.
Fastfox400 is offline
post #2 of 9 Old 08-04-2008, 11:08 PM
ModularSpeed's Avatar
Are you fat?
Race weight should be nowhere near 3600lbs.
Your plans sound pretty good. Everyone has their own opinions of what works better. I have what you listed on the front...except 90/10's instead of strange.
In the rear I have maximum motorsports coilovers, 50/50shocks, Steeda adjuastable uppers, upr solid lowers, no sway bar......my car launches almost perfect....
http://s104.photobucket.com/albums/m...nton12s004.flv
At bradenton before I made any suspension adjustments....(btw..4V with bolt-ons) n/a
2015 S550 GT - 2.3 TVS Powered on 17" Radials
Stock Trans / Stock Converter / 1.28 Sixties
[email protected] Boost --- ([email protected] Boost/Spray)
ModularSpeed is offline
post #3 of 9 Old 08-04-2008, 11:09 PM
Oh and...go with 4.56's
post #4 of 9 Old 08-04-2008, 11:16 PM Thread Starter
I've ran 90/10's before an didnt like how quickly the nose would rise an fall. I had unloading issue in a 93 around the 60' an would blow the tires away.
93 GT- Traded
97 F150-PI swapped.
post #5 of 9 Old 08-05-2008, 06:11 PM
So it was just due to the struts huh? Spring rates, weight, and rear suspension had nothing to do with it?
Non-adjustable struts do not work the same on every set-up.
post #6 of 9 Old 08-05-2008, 08:53 PM
i have the same setup except the rear lowers and i cut 1.4 60s
97TNTCOBRA is offline
post #7 of 9 Old 08-05-2008, 10:34 PM Thread Starter
I changed struts. I went to a Strange adjustable and was able to bring the 60's down to 1.5's and it quitly blowing the tires off at the 60' ft mark.
93 GT- Traded
97 F150-PI swapped.
post #8 of 9 Old 08-06-2008, 05:07 PM
Trader Feedback: (37)
Adam, if you're going with some weight reduction off the front you can run 150's. If no weight reduction then I'd stay with 175's. I noticed with my 175's it didn't transfer as much weight as I wanted to I swapped to 150's. Everything else looks good. Oh don't forget to disconnect the anti roll bar on the street or you'll end up replacing it. -Mark
98 red cobra (N/A 5.4)
[email protected] (1.59 60')
bitemark46 is offline
post #9 of 9 Old 08-06-2008, 10:41 PM Thread Starter
Thanks Mark.
Currently all that has been done up front is a Fiberglass hood from Kanaen, and a full tubular front suspension. Today I got some more thing accomplished. I swapped the Cobra front brakes in favor for GT/V6 from a 98. Even tho they are the same as the 96. I got the car back together with the tubular a-arms an a GMS coil-over kit that came with the car. I'm getting it ready to go over to a local shop for a 6 pt, harnesses, thru the floor sub frames, and Wild Rides torque box reinforcements. Then it comes back to recieve the UPR Pro-series rear kit with sperical bushings, UPR front coil-overs, Strange Struts, Skinny Kid race cars cast/camber plates, an Strange rear adjustable.
P.S. I want a short runner..............................
93 GT- Traded
97 F150-PI swapped.
