8.8 backlash ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-25-2008, 10:06 PM Thread Starter
Trader Feedback: (22)
8.8 backlash ?
with the shims i have can get .006 or .015 which would be better ? 8.8 4.30 gear
351turbo is offline
post #2 of 3 Old 07-26-2008, 01:34 AM
Mattstang65's Avatar
I usually shoot for .008-.011, and then check the pattern. Have always let the pattern dictate if the backlash was to loose or tight, been lucky so far, and I've done several. How did you set the pinion depth? Pinion depth will effect your pattern as well and how the shims influence backlash adjustment. Alot of times you can get lucky just reusing the pinion shim from the 2.73 to 3.08 gearset when going up to 3.55, 3.73 gearing, but when strech it on out to 4.10, 4.30's the shim often needs changed, just my experience. LOL, isn't it fun working on that 8.8 under the car. It's worth pulling the rear completely out from under the car to work on it in my opinion. Richmond gear has pictures of proper gear pattern on their website.
http://www.richmondgear.com/ringandpinion.pdf
91 notch, 408W, 10.5 comp, Jay Allen cam, Crane linkbars, Scorpion rockers, vic jr intake/heads, Canton pan, Mac longtubes, C4, UPR adj. uppers/lowers, Strange struts/shocks, subframe connectors, wild rides 6pt, Team Z k-member/anti-roll bar, MSD ignition.
Mattstang65 is offline
post #3 of 3 Old 07-26-2008, 08:40 AM
blackout50's Avatar
x2
no one knows. thats the issue with EFI, too much guessing.
wisdom from bolt-on-bandito
blackout50 is offline
