255 MT Drag Radials............ - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 07-24-2008, 06:12 PM Thread Starter
5.0roy's Avatar
Who's using them and how fast have you gone with them. I'm trying a set Friday and I'm curious to see what others have done so far. Car has 400rwhp & 420lbtq.............
88 notch...10.38 @ 130.17, 2001 ranger edge.......89 stock lx 13.51 @ 102...........I need a hooptie.......
5.0roy is offline
post #2 of 11 Old 07-24-2008, 07:10 PM
mmb617's Avatar
I have them and while they are way better than the street tires, I still have a lot of trouble hooking. The suspension is all stock though, so that's a problem. I can't launch at more than 2500 without massive wheelspin. I've tried long burnouts, short burnouts, more air pressure, less air pressure, doesn't seem to make much difference.
My 60's are usually around 1.8 - 1.9 and the best pass so far is 12.4 @ 113.
I don't blame the tires for my lack of traction. Hopefully when I can afford some decent suspension it will make a world of difference.
OFR - old fart racing
We're not fast racers. In fact folks call us half fast racers. At least I think that's what they're saying.
mmb617 is offline
post #3 of 11 Old 07-25-2008, 10:28 AM
I've only had them to the track once and I bogged bad subsequently ripping out my upper torque boxes!
I spun at 18psi of air and bogged/broke at 13psi...launching at 4k and a 5-speed...
I've not been back after fixing the car...they hook awesome on the street though...
Mike
86 ascMcLaren Capri | [email protected]
86 Mustang SVO (9L) | [email protected]
www.mikemartinelli.com
n20capri is offline
post #4 of 11 Old 07-25-2008, 12:46 PM
Trader Feedback: (45)
Leroy, i have made 2 passes ont hem so far this year and went 10.50 133mph w 1.7 60 foots. my car isnt set up for leaving on the foot brake, which is what i did. I am sure with some more work i can get the car to go 10.teens with them. Problem is finding them it seems.
mike1174 is offline
post #5 of 11 Old 07-26-2008, 05:00 AM Thread Starter
5.0roy's Avatar
actually, I was looking for 275/60-15's but, they're on backorder............I spun badly with them this weekend, 1.78 was the best 60.......I'm going to put som adj. shocks out back to see if that helps........
5.0roy is offline
post #6 of 11 Old 07-28-2008, 12:43 PM
Len Schmidt's Avatar
Will the 275's fit without rolling the fender lip??
88 LX, 69 410W , AFR ??/70mm T.B., FTI cam, 3.55's, BBK 1 3/4" L.T, Edel 351W Victor intake, ???mm maf, 60 lbs. injectors,MSD, chipped Vortech T trim making 16 psi, MAFtuner, PA AOD - Lentech VB-5000 non-lockup, Mr. Freeze.
Old best 1/4-11.056 @ 123.62 mph Spinning real bad! Old setup
Len Schmidt is offline
post #7 of 11 Old 07-28-2008, 04:24 PM
FN RCKT's Avatar
If the car sits high enough they will. If it squats much the fender will cut the tire.
I used a set of 255/60's for one pass, they spun slightly, still turned a 1.55- 60'. My car runs 1.40-1.43 sixtys on 275/60's.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. -
Thomas Jefferson
FN RCKT is offline
post #8 of 11 Old 07-28-2008, 05:11 PM Thread Starter
5.0roy's Avatar
if you're at stock height out back...........I also turned the rear springs a 1/4 turn to the left to make sure.
5.0roy is offline
post #9 of 11 Old 07-29-2008, 07:43 AM
Thanks guys.
post #10 of 11 Old 08-01-2008, 02:32 AM
Trader Feedback: (178)
I have been a 1.55 on them driving my buddy's 98 Z28 on 255/50/16 MT dr's, auto car with a big converter, car ran 7.3's in the 1/8. Different car but it shows that they CAN work to a point. That car would dead hook from a 20 roll on the street in the middle of winter with no burnout on them and the converter hit VERY hard at 20 mph.
Speeds8erM-1 is offline
post #11 of 11 Old 08-01-2008, 01:58 PM Thread Starter
5.0roy's Avatar
yeah, they're set up for autos, not sticks.......
5.0roy is offline
