5 point harness questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-21-2008, 10:37 PM Thread Starter
bentley429's Avatar
Trader Feedback: (80)
Going to be ordering a s&w 8 point this week($30 until the end of the month btw) so I will need to look into a harness. After looking on summit I saw that there were a few different types to get. As for latch style the camlock looks nice even though it is a bit more. Any comments on regular latch vs camlocks? How about for mounting? Looks like most of the ones I have looked at need some sort of mounting tabs welded to the crossbar for seperate mounting of the shoulder belts. UPR makes a mount for a crotch strap that Iam sure I could just make myself and weld a plate to the floor to mount it on. As for the lap belts can they go in the stock mounting locations? Will be using all grade 8 hardware of course. Pictures would be very helpful. Thanks.
1989 LX- Some stuff.
bentley429 is offline
post #2 of 8 Old 07-21-2008, 11:10 PM
HookandLadder's Avatar
Stock mounting works for the lap. The shoulders can be done without tabs too. Pic included. I used a eyelit bolt throught the floor with welded plates for the crotch mount.
It's Old....Not Slow.
HookandLadder is offline
post #3 of 8 Old 07-21-2008, 11:53 PM
Thriller8's Avatar
I had the tabs welded for the shoulder belts, the crotch one I bought from Holcomb, and the lap belts I used the stock location where they bolted.
X275 build in progress follow on Mustang Junkies.net
http://www.mustangjunkies.net/f9/project-dirty-red-444
Thriller8 is offline
post #4 of 8 Old 07-22-2008, 09:29 AM
Mattstang65's Avatar
Cam lock costs a little more, but is much easier/faster to get in and out of.
91 notch, 408W, 10.5 comp, Jay Allen cam, Crane linkbars, Scorpion rockers, vic jr intake/heads, Canton pan, Mac longtubes, C4, UPR adj. uppers/lowers, Strange struts/shocks, subframe connectors, wild rides 6pt, Team Z k-member/anti-roll bar, MSD ignition.
Mattstang65 is offline
post #5 of 8 Old 07-22-2008, 10:06 AM
ustahava67's Avatar
Trader Feedback: (23)
I set mine up as a wraparound for the shoulder belts. Stock mounting for the laps and I fabbed a crotch mount. I'm OK with the latch style. It's fast enough that I can hook up when I'm the second car back.
Romans 12:2 , 86 GT Bracket Car, 347 carbed/Vic jr's/Parker/ProSys 780/C-4,10.63 @ 125 bullets & Slicks, My dyno is 1320 ft. long.
ustahava67 is offline
post #6 of 8 Old 07-22-2008, 07:01 PM Thread Starter
bentley429's Avatar
Think I decided to go with a g force camlock style 5 point. Is the wrap around style the same thing as hookandladder's setup?
post #7 of 8 Old 07-25-2008, 09:55 PM
BOSS302's Avatar
I would go with an RCI camlock, it comes with a free re-certification card, so in 3 years you send them back to get recertified - for free. Also, I will give you a heads up on the crotch strap, I was using a Wolfe piece that bolts to the front 2 seat bolts.....and that will no longer pass tech (or most I should say). It must mount behind the chest "centerline" to be legal. I ended up welding a seat belt tab on the back of my holcomb bracket and all is good.
BOSS302 is offline
post #8 of 8 Old 07-25-2008, 11:51 PM Thread Starter
bentley429's Avatar
Wow, didnt know that. Deff worth the extra $10 the rci's cost over the g force. Thanks for the heads up on the crotch belt too.
