4.10 gear...does it make sense to switch? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 06-24-2008, 03:34 PM Thread Starter
Currently running a N/A 347 a 3.73 gear on a 26" et street tire with a T-5 in a 3150 lb. car 93GT. My power starts gradually falling off around 5800 rpm. I currently shift at 5600 rpm and hit the traps around 115mph and 5550 rpm. Im trying to rationalize if it really makes sense to go with 4.10 gears when I switch over to a spool. When I have upped my shift point to 5800 I see no benefit in ET. It looks as if I will hit the traps around 6100 with 4.10's. Does it make sense to swap gears in your opinion and if so ...why?
rixx93gt is offline
post #2 of 18 Old 06-24-2008, 04:15 PM
88OrangeLX's Avatar
Do it.
New times coming soon.....
88OrangeLX is offline
post #3 of 18 Old 06-24-2008, 04:30 PM Thread Starter
Any reason or like the Nike commercial...just do it?
rixx93gt is offline
post #4 of 18 Old 06-24-2008, 05:36 PM
memphis306's Avatar
it makes no sense to do it right now.have you ever tried to speedshift 5th??? until you get your motor to rev higher,leave it alone.
memphis306 is offline
post #5 of 18 Old 06-24-2008, 06:15 PM
93mustank's Avatar
Trader Feedback: (133)
Shift into 5th? why?
www.facebook.com/FoxBodyPerformance
93mustank is offline
post #6 of 18 Old 06-25-2008, 10:46 AM Thread Starter
I dont know why I would shift into fifth? Im talking about going from a 3.73 to a 4.10 not the other way around.
rixx93gt is offline
post #7 of 18 Old 06-25-2008, 10:55 AM
2002mustanggt's Avatar
don't do it.
2002mustanggt is offline
post #8 of 18 Old 06-25-2008, 11:35 AM
memphis306's Avatar
obviously,you're not the sharpest tool in the shed
post #9 of 18 Old 06-25-2008, 12:01 PM
If you're going through the traps almost at your shift point now, installing lower gears will make that rpm higher thus the need for another gear with the motor the way it is now. T5s do not like to go into 5th fast plus there is a much bigger difference between 4th and 5th than any other two gears. Also this last shift will happen right at the finish line=something you never want to happen with any car. You must stay in 4th gear or you ET will fall off. The real problem is not being able to go past 5800 or so without power falling off. A 347 is capable of more than that easily depending on how it's set up.
88 coupe, 351 cleveland, unported 4V heads, buddy rawls custom solid roller, diamond domes, 6'' h-beam rods, stock 4bolt block/crank, holley strip dominator, 950HP holley, hoosier 28x10, 90/10s, UPR pro rear kit
nonstroked, stock iron heads and NO NITROUS!!!!!!!!
[email protected] / [email protected] (1/8th)
All Cleveland is offline
post #10 of 18 Old 06-25-2008, 01:02 PM Thread Starter
Hmmmm, obviously your an ass....hows that Einstein? Listen carefully. I currently dont trap above my useable power range...why would I shift into fifth gear? Now when and if I install the 4.10's I could see your point however dull it may be.. As seen above Im not the only one who thought your reply was...lame. Unless you are being sarcastic which doesnt come through so good on a keyboard.
rixx93gt is offline
post #11 of 18 Old 06-25-2008, 01:08 PM Thread Starter
Yes I understand, my cam is a bit smallish due to having to pass emissions checks back in the day. I would never want to set my car up to shift into 5th gear as some suggest due to the reasons you just mentioned. I have been told by some that I may still see a slight advantage to the 4.10s even before I make a cam switch due to my car weight. Thanks for your reply.
rixx93gt is offline
post #12 of 18 Old 06-25-2008, 01:13 PM
Blk88GT's Avatar
I would find the reason for the lack of upper RPM power first. The combination could have simply been designed that way. More RPM doesn't always make you go faster.
What does Ed say?
Ian
1988 Mustang GT - 422w/IS plate
[email protected] (1.26 60ft) best 1/4 mile
[email protected] (1.31 60ft on the back tires) best 1/8 mile
Blk88GT is offline
post #13 of 18 Old 06-25-2008, 02:39 PM
memphis306's Avatar
in my first post i said dont do it. asking if you had ever tried to speedshift 5th was a rhetorical question meaning its damn near impossible and when you do finally get it in,it bogs the hell out of the motor.i wasn telling you to try it with your current setup,which is almost perfect as your crossing the traps at or near the top of your usable rpm range. i thought it was obvious that i was saying if you switched to 4.10's and ran the same mph or faster,you would have no option except to shift to 5th.hence,why i said dont do it.maybe my sarcasm and the extra question marks didnt come through as intended.on my second post,i was being an ass because i didnt know what the hell you were trying to say.go back and read my 1st post again and you should see where i was coming from
post #14 of 18 Old 06-25-2008, 02:58 PM Thread Starter
Thanks for explaining that. I got it. Sounds like if I change gears now while I have it apart I can expect nearly the same et's or worse. I realize I need a more aggressive cam profile and after changing cams I may see an advantage to the 4.10's if my power band raises up say 300 or so rpm?
rixx93gt is offline
post #15 of 18 Old 06-25-2008, 06:20 PM
Mattstang65's Avatar
If power "gradually" starts dropping off at 5800, the 4.10's should still benefit you. If it flattens out at 5600-5800, then you'll probably slow down or stay the same. If the car hooks well, your 60 fts may improve with the 4.10s possibly helping out with ET.
91 notch, 408W, 10.5 comp, Jay Allen cam, Crane linkbars, Scorpion rockers, vic jr intake/heads, Canton pan, Mac longtubes, C4, UPR adj. uppers/lowers, Strange struts/shocks, subframe connectors, wild rides 6pt, Team Z k-member/anti-roll bar, MSD ignition.
Mattstang65 is offline
post #16 of 18 Old 06-26-2008, 01:29 AM
sooner89's Avatar
Trader Feedback: (18)
I also have a 347 but with a T-56. I just switched my gears from 4.10's to 3.73's. But I also shift at around 6200. I have noticed quite a difference with the new gears and will test them at the track soon. Keep the 3.73's if you ask me.
89GT-347, Vortech S-trim (7 psi), Trickflow (intake, heads, pistons), Meth/water injection, T-56, FAST dual wideband, BBK LT's, FMS 3.73, SCT chip, CHE axle brace, TA performance Girdle, and M/T DR's.
sooner89 is offline
post #17 of 18 Old 06-26-2008, 02:27 AM
I have the same set up as you and I ues a 4.10 I go 114.88 at 11.91 with a 60 FT 1.62 I go throw the trapes at 5900
bradsspeedshop is offline
post #18 of 18 Old 06-26-2008, 07:01 AM
88OrangeLX's Avatar
That was my reasoning, I just didn't feel like typing it out. I was thinking more of in the first part of the track rather than the last.
