29.5x105W's and a mini tub - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 06-15-2008, 03:12 AM Thread Starter
jds95's Avatar
Will 29.5x10.5W's fit under a mini tub. According to the M/T website, they are about the same size as a 29.5x11.5. But , I was told they are bigger. Is this true. I don't want to order the wrong tires.
86' GT, 414 windsor w/ Procomp heads.World Products dominator intake. Jerico DR4 w/Long vertigate shifter, Boninfante 10.5in clutch. Mini Tubbed. classicgearjammers.org
jds95 is offline
post #2 of 2 Old 06-15-2008, 12:50 PM
I think width wise you's be fine, but the wheel well may not be big enough front to back on the car...
I'm having to trim (open up) that area on my car to fit a 315-60-15 radial. (30" tire.) Your problem is the 29.5 will grow to ?????? At the top end. So the tire will be narrower, but taller, and that's where you would see an issue.
O.G. X275 racer
1.17 60' [email protected] with the angry peanut!
1.16 60' [email protected] on 1 gun (In testing)
88gtguy is offline
