26 or 28 et drags? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 06-06-2008, 11:27 AM Thread Starter
Trader Feedback: (38)
26 or 28 et drags?
2900 lb,306 vortech 600 whp,3.27 1st-tko trans,135 trap speed,3.55 or 3.73 not sure yet
Marty White is offline
post #2 of 14 Old 06-06-2008, 01:27 PM
What width? Remember with a larger diameter you get more tread contact area. I would go with 28's.
-Thomas
Thomas is offline
post #3 of 14 Old 06-06-2008, 01:40 PM
Formerly known as 20thAniv
Unatural's Avatar
28s. With that much power and a stick, the taller sidewall will work to your advantage. Also, go with the stiff sidewall too for the same reason that it's a stick.
The rpm to you turn the motor to will determine what gear you need. Take a look at the mph calculator on here. That will pretty much tell you what you need.
Wayne
'91 LX Hatch
Single turbo
, KWS Images on FB and IG
https://forums.corral.net/forums/turbochargers/1379238-unaturals-diy-build.html
Unatural is offline
post #4 of 14 Old 06-06-2008, 08:11 PM Thread Starter
i just want some stout 60ft's,not kill the gear too bad-never ran 28's always heard they were a little more stable at the top end
post #5 of 14 Old 06-06-2008, 09:30 PM
1foxbody32's Avatar
Trader Feedback: (26)
Go with the 28's you won't regret it.
SIRACING.NET
1foxbody32 is offline
post #6 of 14 Old 06-06-2008, 10:12 PM
gray86hatch's Avatar
Trader Feedback: (98)
With that combo NMRA RS guys claim that the new MT stiff 26 -10 are the ticket.
Tim
86 mustang
www.flowtechinduction.com
gray86hatch is offline
post #7 of 14 Old 06-06-2008, 10:27 PM Thread Starter
yeah,26x10's fit on my 15x8's perfect-they're isn't any more room now,it's basically going to be a real street combo-i don't know if a 28x10.5 will fit,i think it might kill 1st gear with the 28's and i'm leaning toward 3.55's
post #8 of 14 Old 06-07-2008, 01:09 AM
KEVIN$'s Avatar
Tim
Don't forget that these guys run 250lbs in the rear bumper and launch at 7000 rpm so they need the stiffer sidewall..
ks
Kevin Slaby
KEVIN$ is offline
post #9 of 14 Old 06-07-2008, 01:25 AM
bod89lx's Avatar
Trader Feedback: (88)
Well a 28" tire will be much easier to get to hook, but will soak up a little more power and with more side wall they will be less stable than the 26" tires will be. Keep in mind the 28's will grow a little at higher speeds which will affect your gear cacluations a bit. The 26's will fit real good but will need a little more work to get to hook as good as the 28's but can be done.
2013 GT500 SGM \Black Stripe.
2003 Cobra Redfire
1986 GT 408W C4 T-Top Factory Paint
2013 Ram 2500
bod89lx is offline
post #10 of 14 Old 06-07-2008, 02:42 AM
PMS Tuning Forum Moderator
Redsnk95's Avatar
As far as stability, my 28" stiff walls are great on the big end. Mine do NOT walk around at all.
If you have the room I would go for the 28" stiff wall if possible with the 3.73 gear ratio.
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #11 of 14 Old 06-07-2008, 09:00 AM
ponie1992's Avatar
I would suggest 28x9's if you think you will have clearance issues.
John 3:16
2016 Ruby Red PP GT
ponie1992 is offline
post #12 of 14 Old 06-07-2008, 09:13 AM
88OrangeLX's Avatar
26x10s here and running a 4.10 gear launching at 6000+ RPMS trapping in the 11x's have not had one bit of walk on the big end.
New times coming soon.....
88OrangeLX is offline
post #13 of 14 Old 06-07-2008, 09:15 AM
chvyeter's Avatar
I've got 28 inch tall slicks and bog everytime off the line with 3.73 gears and TKO 600 trans even when launching at 6k so far, still have stock axles. I don't bog as much on the bottle but still do. I'd either go with 26 or get more gear.
8.0 @ 88 on motor, old 306
7.0 @ 100 on new engine combo
6.4 @ 108 letting out twice on bottle.
11.2 @ 126 in 1/4 on motor
chvyeter is offline
post #14 of 14 Old 06-07-2008, 09:16 AM
chvyeter's Avatar
I had to clearance the crap out of the inner fenders to get them to fit but they still rub a little if I turn very fast.
chvyeter is offline
