2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 31 Old 10-05-2015, 03:05 PM Thread Starter
Diode Dynamics's Avatar
Arrow 2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade!
2013-2014 Ford Mustang DRL LED Boards
Upgrade your Mustang's factory DRLs with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2013-2014 Ford Mustang. Your order includes a full set of panels, as well as drivers to safely and reliably power them.
From the factory, the DRLs in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Your Experts in All Mustang Lighting!
(314) 205-3033
Diode Dynamics is offline
post #2 of 31 Old 10-07-2015, 11:33 AM Thread Starter
(314) 205-3033
post #3 of 31 Old 10-09-2015, 08:56 AM Thread Starter
(314) 205-3033
post #4 of 31 Old 10-12-2015, 04:23 PM Thread Starter
(314) 205-3033
post #5 of 31 Old 10-15-2015, 10:13 AM Thread Starter
(314) 205-3033
post #6 of 31 Old 01-28-2016, 09:15 AM Thread Starter
Customer Submitted Photo
These LED Board replacements fit all 2013-2014 Mustang models
Nick C.
(314) 205-3033
post #7 of 31 Old 03-25-2016, 09:48 AM Thread Starter
(314) 205-3033
post #8 of 31 Old 05-25-2016, 05:22 PM Thread Starter
Customer Submitted Photo - Notorious Photography: https://www.facebook.com/TheNotoriou...raphy/timeline
Nick C.
(314) 205-3033
post #9 of 31 Old 05-26-2016, 09:59 AM Thread Starter
Nick C.
(314) 205-3033
post #10 of 31 Old 05-27-2016, 09:52 AM Thread Starter
Nick C.
(314) 205-3033
post #11 of 31 Old 08-16-2016, 05:03 PM Thread Starter
Nick C.
(314) 205-3033
post #12 of 31 Old 08-30-2016, 12:51 PM Thread Starter
PapaSmurf 5.0!
Nick C.
(314) 205-3033
post #13 of 31 Old 10-03-2016, 03:30 PM Thread Starter
South Texas Stangs
Nick C.
(314) 205-3033
post #14 of 31 Old 10-11-2016, 12:31 PM Thread Starter
Nick C.
(314) 205-3033
post #15 of 31 Old 03-09-2017, 12:45 PM Thread Starter
(314) 205-3033
post #16 of 31 Old 03-30-2017, 04:04 PM Thread Starter
(314) 205-3033
post #17 of 31 Old 04-04-2017, 09:50 AM Thread Starter
2013-2014 Ford Mustang Switchback DRL LED Boards by Diode Dynamics
(314) 205-3033
post #18 of 31 Old 04-06-2017, 03:53 PM Thread Starter
PS Lighting Solutions
(314) 205-3033
post #19 of 31 Old 05-09-2017, 02:03 PM Thread Starter
Photo Credit: UAE Drag Racing
(314) 205-3033
post #20 of 31 Old 05-26-2017, 11:25 AM Thread Starter
Diode Dynamics: 2013-2014 Mustang S197 RGBW Multicolor Color Changing DRL LED Boards!
(314) 205-3033
post #21 of 31 Old 06-29-2017, 09:08 AM Thread Starter
Featuring Diode Dynamics HDHalos & 2013-2014 Mustang RGBW DRL LED Board Replacements (USA Made!)
@ Jflyyy_3.7
(314) 205-3033
post #22 of 31 Old 07-07-2017, 04:31 PM Thread Starter
Featuring Diode Dynamics 2013-2014 GT500 RGBW DRL LED Board Replacements (USA Made!)
@ Mando_14SVT
(314) 205-3033
post #23 of 31 Old 07-17-2017, 06:17 PM Thread Starter
@ Jflyyy_3.7
(314) 205-3033
post #24 of 31 Old 07-19-2017, 03:07 PM Thread Starter
Diode Dynamics 2013-2014 Mustang RGBW Multicolor DRL LED Board Replacements (USA Made!)
@ curivisualmedia
(314) 205-3033
post #25 of 31 Old 08-03-2017, 09:34 AM Thread Starter
Diode Dynamics: 2013-2014 Mustang RGBW Multicolor DRL LED Board Replacements (USA Made!)
@ danielbecerra_5.0
(314) 205-3033
post #26 of 31 Old 08-07-2017, 04:44 PM Thread Starter
Owner IG: Alexturner_3.7
Diode Dynamics RGBW Multicolor LED boards & Demon Eyes Installed
(314) 205-3033
post #27 of 31 Old 08-23-2017, 04:58 PM Thread Starter
Owner IG: Panda3
Diode Dynamics RGBW Multicolor LED boards installed
(314) 205-3033
post #28 of 31 Old 09-18-2017, 11:03 AM Thread Starter
Owner IG: Markyoung
Diode Dynamics 2013-2014 RGBW Multicolor LED boards for 2013-2014 Ford Mustang & RGBW Demon Eyes Installed
(Also has a Diode Dynamics Stage Series light bar mounted in the lower grille!)
(314) 205-3033
post #29 of 31 Old 10-03-2017, 12:41 PM Thread Starter
(314) 205-3033
post #30 of 31 Old 11-20-2017, 04:12 PM Thread Starter
(314) 205-3033
post #31 of 31 Old 07-05-2019, 05:40 PM Thread Starter
Don't forget to shoot us a PM for free USPS shipping on any U.S order!
Jake H.
Diode Dynamics
(314) 205-3033
Looking for other members with cylinder 8 failures 19kobra99 S-197 Mustang GT (2011-2014) 63 07-29-2011 07:27 AM
For Sale 1989 Mustang LX 5.0L FULLY BUILT/RESTORED/Custom Dash! BOSSGT Mustangs For Sale/Wanted, 1987-1993 1 05-29-2011 07:43 AM
