408 Windsor custom cam opinions please - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-29-2019, 08:40 PM Thread Starter
Hi there, I've been learning from this and many other forums for the last 3 years whilst building my dream car.
Hoping for some opinions on my custom cam for my build. I have the cam, however my engine builder is shortly starting on the engine, the engine build and transmission are being outsourced, expensive things to mess up 👍. His opinion is its too mild a grind for my goals.
On the cam sheet I listed my Complete build, plus goal of street/strip usage, 525hp/tq.
Build as follows
67 stang
10.44 to 1 compression
95 Ron uk petrol/gas
1974 351 block stroked to 408
6208 long tube headers 1 3/4"
Weiand stealth intake (to keep under stock indicator hood)
3" dual exhaust
Lunati hyd link lifters
Crane cams gold rockers
770cfm Street avenger ultra carb
Truetrac 3.25 diff
3/8 fuel line, Victor mech fuel pump with regulator
AFR 205 58cc heads
The custom comp cam supplied, bearing in mind I wanted to get over the 500 hp/tq Mark at the crank has the following details. I'd appreciate some opinions on whether this will be sufficient to achieve what I want. I'd rather deal with it now if it's confirmed the grind will fall short.
Cam sheet in picture
Any feedback welcome, it's been a long hard 3 years but getting there now, nearly finished.
File Type: jpg Screenshot_20190330-003602_1553906359951.jpg (33.1 KB, 19 views)
Paul Godwin is offline
post #2 of 6 Old 03-29-2019, 08:45 PM Thread Starter
Three years of challenges,
post #3 of 6 Old 03-29-2019, 08:48 PM Thread Starter
Compression is 10.44 to 1, running on 95ron UK petrol. Thanks
post #4 of 6 Old 04-04-2019, 05:07 PM
Curt C's Avatar
Go post this in the 5.0 / 5.8 tech forum under Windsor tech and you will get a much better response.
1986-045 Saleen Mustang Griggs GR40, 408W RDI aluminum block, AFR 205, T56
1999 Porsche 911 Carerra - Stock
1999 BMW M Coupe - Stock
Curt C is offline
post #5 of 6 Old 04-04-2019, 05:14 PM
AtomicCoupe's Avatar
I’m no help, but awesome car!!
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is online now
post #6 of 6 Old 04-14-2019, 01:19 PM Thread Starter
Thanks fella 😁😁👍
351W cam change- opinions? braxus 5.0/5.8 Engine Tech 8 02-01-2010 07:18 AM
1st HCI swap???? 94_Darkhorse General Mustang Tech 6 06-13-2007 11:13 PM
Are 4.30's or 4.10's too much gear? mustang347gt General Mustang Tech 63 05-27-2007 12:19 AM
Instaling heads & cam pd93lx 5.0/5.8 Engine Tech 6 04-03-2005 12:59 AM
E Cam vs F Cam, tailpipe emissions old lx 5.0/5.8 Engine Tech 0 03-15-2004 09:12 PM
