65 mustang swap parts - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 32 Old 05-22-2012, 10:57 PM Thread Starter
cooper1320's Avatar
guna be buying a 1965 mustang 289 v8 and i was wondering if there any interchangable parts that fit the 65?
braking, suspension, steering components and so one
cooper1320 is offline
post #2 of 32 Old 05-23-2012, 08:44 AM
jevchance's Avatar
So you're asking if '65 Mustang parts will swap onto a '65 Mustang?
about.me/jevchance
myrestoproject.com - coming soon!
1966 Mustang Coupe
jevchance is offline
post #3 of 32 Old 05-23-2012, 12:58 PM Thread Starter
cooper1320's Avatar
no if there any moderen parts that will swap in, ei. the rear end of a sn95 or the brakes off another mustang.
post #4 of 32 Old 05-23-2012, 01:00 PM
Talking
Granda front disc brakes will fit.http://www.google.com/url?sa=t&rct=j...svzf5GBn61Utsghttp://www.google.com/url?sa=t&rct=j...2na3vMazPt5avQ
racerxmdd is offline
post #5 of 32 Old 05-23-2012, 02:55 PM
jevchance's Avatar
Nothing will bolt right in.
However, there are a lot of modifications that people will do to incorporate newer parts into older cars.
Some popular ones, in addition to racerxmdd's granada front disc brake swap are:
1) Roller 5.0 from an 86-93 Mustang, with or without fuel injection
2) AOD (automatic overdrive) transmission from a 80's-early 90's Ford, including Mustang
3) Dual-bowl master cylinder for safety
4) 8.8 inch rear end from a Fox Mustang
5) T-5 transmission to replace a factory 4-speed
about.me/jevchance
1966 Mustang Coupe
post #6 of 32 Old 05-24-2012, 05:04 PM
I have seen a lot of people swap 8.8s out of Explorers in. I never have looked into why but just assumed it must take the least amount of work to do. But perhaps it is just because of cost reasons.
Sent from my iPad Nano
post #7 of 32 Old 05-24-2012, 05:15 PM
jevchance's Avatar
Probably cheaper and more plentiful in the junkyard. I know the rears from a Mustang GT are guaranteed to have traction-loc, but the Explorers aren't guaranteed to, you have to check the data plate. I don't know about the width differences. Its possible the Explorers came with disc brakes, that would make it an attractive option.
about.me/jevchance
1966 Mustang Coupe
post #8 of 32 Old 05-24-2012, 05:21 PM
Talking
Also, do a T-5 Trans. Swap and do the MOD the the Clutch Pedal so it will accept a Clutch Cable. There is also a kit that let's you install Rack-N-Pinion to old classic Mustangs.
post #9 of 32 Old 05-24-2012, 05:23 PM
As I remember all 8.8s in V8 Explorers came with rear disc brakes. I think steeper gearing than their mustang cousins. Pretty sure they are also a different width than the Mustangs. Of course all GT Muatangs since 1994 also have rear discs. I'd thought those Mustang rearend aren't a whole lot different in cost from the boneyard.
I can't say for certain on the diffs but sure thought the Explorers had traction locks. Maybe even 31 splines but betting 28s. Regardless it is something worth looking into for a stranger rear end and better brakes all in one reasonably priced modern packaged upgrade.
post #10 of 32 Old 05-24-2012, 05:25 PM
I personally would not do a T5 given how weak they are. But guess it depends on what(if anything) is done to the engine for power. If it is a 4-speed car and a top loader instead of a T-10(?) then I'd just keep that. But I never have had overdrive high up on my wish lists.
post #11 of 32 Old 05-24-2012, 08:21 PM
Talking
I did a 5-speed swap when I had my '65 Fastback. But my trans was a Tremec TKO. I liked that I had a Over-Drive, made a Big Difference. I still have pics of the MOD that is needed on the clutch pedal for the clutch cable up-grade if needed.
post #12 of 32 Old 05-25-2012, 09:11 AM
jevchance's Avatar
The T-5 is adequate for up to about 300HP.
Overdrive is a huge gas saver. My 1966 289 C4 would get close to 20MPG at 55MPH, and about 14MPH at 70MPH.
about.me/jevchance
1966 Mustang Coupe
post #13 of 32 Old 05-25-2012, 09:33 AM
I know plenty of people who broke plenty of T5s in stone stock Fox body Mustangs which is a far cry from 300 hp though different weight car. My point being here that they can be broken much easier than say the previously mentioned Tremec TKO can. But I suppose it all boils down to why you are doing the swap and what you are going to use the car for. If the car is not going to be daily driven then I'd not waste my time swapping to a 5-speed if it is a 4-speed already and if that 4-speed is a Top Loader. But I am just assuming here that someone who is wanting to put modern tech on the car is going to want to modify it for more power.
post #14 of 32 Old 05-25-2012, 10:04 AM
jevchance's Avatar
I can only assume he isn't adding more power based on the OP, but who knows.
about.me/jevchance
1966 Mustang Coupe
post #15 of 32 Old 05-27-2012, 07:45 PM
KILLemALL's Avatar
Isnt torque the issue with the t-5s?I thought they were rated for torque.
KILLemALL is offline
post #16 of 32 Old 05-27-2012, 09:00 PM
jevchance's Avatar
Too much torque tends to break 3rd gear in a T-5.
about.me/jevchance
1966 Mustang Coupe
post #17 of 32 Old 05-28-2012, 12:40 PM
Shifting too hard into 3rd will grenade them too if you lack a shifter with good or properly adjust stops. The ford shifters on the Fox bodies lacked that and why a lot of people killed their T5s.
post #18 of 32 Old 05-30-2012, 11:00 PM Thread Starter
cooper1320's Avatar
whats the simplest n not to costly way to change the alt to 3g, go disc brakes all around and upgrade to modern power steering??
post #19 of 32 Old 05-31-2012, 08:42 AM
jevchance's Avatar
Via Google:
MustangSteve's GRANADA to MUSTANG DISC BRAKE INSTALLATION INFORMATION
Step by Step 3G Alternator Upgrade 1965 Mustang
1966 Ford Mustang - Project '66 - How To: '65-'66 Power-Steering Conversiong - Mustang Monthly Magazine
HTH
about.me/jevchance
1966 Mustang Coupe
post #20 of 32 Old 06-01-2012, 03:34 PM
1995CobraR's Avatar
I think the front Lincoln brakes are the better option.
1995 Cobra R
2014 Porsche 911
2019 Mustang GT350
15 Year Corral Member
1995CobraR is offline
post #21 of 32 Old 06-01-2012, 04:16 PM
jevchance's Avatar
Do you have more info/link on the Lincoln swap?
about.me/jevchance
1966 Mustang Coupe
post #22 of 32 Old 06-01-2012, 09:13 PM
1995CobraR's Avatar
I bought all of my parts several years ago. They work well for me.
"Cobra Automotive" brakes, suspensions & steering parts
1995 Cobra R
2014 Porsche 911
2019 Mustang GT350
post #23 of 32 Old 06-06-2012, 10:15 AM
Don't tell that to the T5Z in my signature, it lived happily behind a nitroused 347 for several years.
As mentioned, a good aftermarket shifter and don't power shift 3rd gear are the keys.
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, FiTech EFI, EDIS/MegaJolt ignition, long headers), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcdaniel is offline
post #24 of 32 Old 06-06-2012, 10:53 PM Thread Starter
cooper1320's Avatar
thanks for that link for the 3g alt!, i guna keep to auto transmisson for now, what would be the cheapest ford car/truck to pull out a c4 trans from??
post #25 of 32 Old 06-07-2012, 08:40 AM
jevchance's Avatar
Wherever you can find one in a junkyard. They used them in a LOT of vehicles. There's a list here:
Ford C4 transmission - Wikipedia, the free encyclopedia
You should be able to find a cheap one in a Fairmont, Granada or LTD.
I highly recommend taking a good look at the AOD swap before picking up a C4. Its not too difficult or expensive, the transmissions are widely available, and gaining overdrive will save you a lot of money in gas in the future.
about.me/jevchance
1966 Mustang Coupe
post #26 of 32 Old 06-07-2012, 05:02 PM Thread Starter
cooper1320's Avatar
that sounds better, which car had AOD's in them?? and do u know of a write up i can check out
post #27 of 32 Old 06-07-2012, 05:05 PM
jevchance's Avatar
86-93 Mustang. Lots of transmissions available, search your local Craigslist for AOD. I can almost guarantee you'll find one on your first try.
Here's a good article: Ford Transmission Swap - Overdrive Transmission Upgrade - Mustang Monthly Magazine"
Beyond that just google 'AOD Swap' and you'll get a ton of videos and discussions. HTH.
about.me/jevchance
1966 Mustang Coupe
post #28 of 32 Old 06-07-2012, 08:11 PM
keithnra's Avatar
Trader Feedback: (29)
Nice thread to follow
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
99 GT
99GT vert
keithnra is offline
post #29 of 32 Old 06-08-2012, 02:31 PM
AJE has a front and rear kit that will let you use engine,spindles,brakes,rack, and rearend from 87-04 Mustangs in the early Mustangs. Even some of the 79-86 parts will work.
Anthony Jones is offline
post #30 of 32 Old 06-24-2012, 09:36 PM
Resident Curmudgeon
toybreaker's Avatar
do a google search for $200 disc brakes. there is a good thread on one of the mustang message boards (I can't remember which one now) I did it on my 70. the only thing you can't buy is the spacers. I made mine. I also got my rotors and calipers from a salvage yard. I did the whole swap for $145.
If you get a 4x4 explorer rear it has Posi and 31 spline axles. the pumpkin is slightly off-center but it does not interfere with operation unlees the car is slammed and you bottom out the suspension, then the driveshaft "MIGHT" rub on the trans tunnel. You will need to modify the emergency brake cable as well.
the fix for the off center part is to cut the drivers side tube down to use another passenger side axle and weld it back up.
The AOD swap would benefit a driver car. If you are just going to cruise it leave the C4 in it. You can get it rebuilt pretty cheaply. Find a shop that will do a bench rebuild so you can save on the labor to pull it and install it. Make sure they will warranty it though.
some shops won't if they don't install it.
Oh when you do that buy new trans cooler lines they are cheap and everything will go together beautifully. Flush the trans cooler in the radiator as well.
When i get back from the middle of nowhere I am doing a 5 speed swap in my 70.
It has the $200 disc brakes, exploder rear with discs and 3.55 gears and a slightly warmed over 347 with world products heads and a performer rpm intake
toybreaker is offline
post #31 of 32 Old 06-30-2019, 11:53 AM
navyflyer72's Avatar
Great thread to follow!
Navyflyer
Maryland (but not for long)
navyflyer72 is offline
post #32 of 32 Old 07-01-2019, 10:44 AM
TaraFirma's Avatar
If you haven't already, check out https://www.vintage-mustang.com/
Huge amount of info for the early Mustangs. The T5 can be installed, 3G ALT upgrades, and you can even put Cobra brakes on them up front. Pretty much anything you can think of has already been done. You've just got a lot of reading to do. So far on my wife's 65, Iv'e swapped out a GT40P engine, replaced all the BS steering components with more modern stuff, and replaced all the stereo equipment. Replacing all the AC and power/disc brake upgrade is next.
To fly is Heavenly, to hover is divine.
Don't let your mouth write a check your a$$ can't cash.
TaraFirma is offline
For Sale 1995 MUSTANG GT 2 CARS FOR PRICE OF ONE! speedracer89 Mustangs For Sale/Wanted, 1994-1998 1 04-24-2012 10:20 PM
