94/95 Mustang 5.0 gas/fuel lines/fire hazard issues ---> - Page 6 - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
post #176 of 197 Old 02-01-2011, 11:56 AM
Originally Posted by 89llx View Post
I have a bone stock 95 gt with 260,000 miles and never had this problem, could it only be the modded ones where they get bumped and moved?
Not really.... they just get brittle over time and eventually they break. You may not notice it until you start moving stuff around but they will break at some point.
95 GT Convert|347 stroker
95 Cobra coupe|Rotrex supercharged|Sold
Former Dr.Gas X pipe distributor.
MRBiggs is offline
post #177 of 197 Old 02-04-2011, 04:25 PM
FastGT94's Avatar
Trader Feedback: (37)
^this.
I bet yours might still be brittle but if you don't move em too much, you might be ok. Just keep an eye on things IMO
-Dale
1994 Mustang GT TKO 500 5 spd
Fox 75mm TB, FTI Ported Edelbrock Perf RPM, 58cc AFR 165s, FTI Cam, 4.10s, Drag Susp, PMS Tuned by Mike Post
316 RWHP & 335 RWTQ // 3,225 lbs with driver and fuel // 11.919 @ 113.92 All Motor
FastGT94 is offline
post #178 of 197 Old 02-07-2011, 06:31 PM
I haven't noticed a fuel smell but I would love to replace my hoses just to be safe. BUMP!
T5killer95 is offline
post #179 of 197 Old 03-03-2011, 01:07 AM
Will v6 fuel line set up work on a 94 cobra. I had removed the lines on mines and got 1 kinked pretty bad, it may have cracked the nylon hose underneath the rubber outer.
IBleedBLUE302 is offline
post #180 of 197 Old 03-17-2011, 03:43 PM
Just had this issue been parked for 6 mnths when started could smell fuel and didn't pay it any mind and drove the car about a day or two later checking the car getting ready to go cruze with the guys. Low and behold a fuel leak on the passenger side rale at the injectors. Replaced the o-rings and all was well. O-rings still seemed good but replaced it anyway.
WARRSTANG331 is offline
post #181 of 197 Old 11-26-2011, 10:40 AM
johnny turbo5.0's Avatar
PICS.....
johnny turbo5.0 is offline
post #182 of 197 Old 05-22-2012, 05:58 AM
Best thing to do is rip out that stock fuel setup.
I removed the entire set up and replaced it with a granatelli in tank hanger delete, a external magnafuel quickstar 275 pump, trickflow 100 micron fliter and aeroquip lines and fittings..those little metal lines along the frame are very easy to remove, the tank hanger will cause some frustatration upon removal, and filler neck seal will need replaced...spend a little time and money and youll be able to replace that yucky stock system
1995 GTS - Fox lake racing forged 347 stroker,tremec 3550,TSW snettertons,nitto invo's,Steeda suspension,my lil grocery getter
slivers is offline
post #183 of 197 Old 05-22-2012, 11:16 AM
Well that sounds totally reasonable for a street car with a leaky hose at the rail....
I think you may have missed the point of this exercise.
MRBiggs is offline
post #184 of 197 Old 06-01-2012, 08:57 PM
Pics anyone?
nkologiski2579 is offline
post #185 of 197 Old 06-02-2012, 04:56 PM
MRBiggs is offline
post #186 of 197 Old 06-14-2012, 12:57 PM
MRBIGS, did you use the Russell fittings then do the SS braided lines?
I'm about to start building my car to run in NMRA Factory stock, but we are about to pull the powertrain out to clean the engine compartment up. I want to fix any potentional problems now.
Thanks,
94 GT
86LX5_0 is offline
post #187 of 197 Old 06-14-2012, 03:09 PM
Thanks,
94 GT
I used the russell fittings and fragola lines as mentioned a couple pages back. Works really well, but I kinda wish I had gotten a tighter bend on the rail side at the return outlet so its not in the way so much. But oh well... next time maybe.
MRBiggs is offline
post #188 of 197 Old 07-29-2012, 11:15 AM
wayne94mustang's Avatar
A few months ago I started smelling a faint fuel smell around my 94 that i could never pin point or find a leak of any kind. I remembered these threads on here about this and decided to just go for it. I ordered all the parts from Summit Racing including the 30'' Fragola pre made SS lines.
I ordered one line with a 45 and one with a 90 degree bend and could not be happier with the fit.
With the fox valve covers I ran the new lines just like I ran factory rubber lines with one on each side of the filler tube.
I even used the factory fuel line holder that's on the shock tower. I sliced some 1/2'' clear tubing and put it over the SS line to keep it from rubbing on my paint at the shock tower.
The fuel smell went away and the SS lines and blue fittings look great!
94 gt auto becontrolls.com stand alone tranny computer,3000 stall,trannsgo shift kit,3.90s,31 moser axles, qa1 k-member,kb frame ties,mega bite lowers,comp extreme 270-276 dur .544 lift,#24 injecters,pro-m bullit meter,mac cai,pih kit,and all the little bolt ons
wayne94mustang is offline
post #189 of 197 Old 08-19-2012, 09:50 AM
Can you post the art numbers you used for those of us too lazy to look for it all?
Lemondrop is offline
post #190 of 197 Old 07-10-2013, 02:52 PM
P63
Moderator
P63's Avatar
Trader Feedback: (15)
Will these parts fit our cars?
http://www.summitracing.com/parts/rus-651104
Victor Marshall
Copyright 2019.
P63 is offline
post #191 of 197 Old 07-11-2013, 12:09 AM
Short Circuit's Avatar
Trader Feedback: (74)
They look too short sir.
Short Circuit is offline
post #192 of 197 Old 12-01-2013, 03:20 PM
ibayter's Avatar
Nice to know this web site, anybody have try the new product "Street Force"? I was reading about it but would like to know an actual owner experience with the kit. it looks nice! I want to buy it! Please any comments about this product let me know. Thanks,
ibayter is offline
post #193 of 197 Old 10-17-2017, 12:43 PM
Having a little trouble getting the return line fitting 640870 to snap back on to the OEM fuel rail... The fitting slides all the way into the rail neck to where the lip of the fuel rail neck is inside the blue oval hub, but no matter how hand I try, it just will not snap into place.
The feed line went on ok.
Anyone had this issue?
Am I doing something wrong?!
The OEM and 640870 visually look the same, so I have no idea....
Ride: 1995 GT ... work in progress ...
| Factory 302 SB | 195 Canfields | RPM2 Intake | CI Cam | Probe Shafts 1.6 | 80mm PMAS | 39# Inj | Tweecer R/T | Mac LTs 1 3/4 | Pro chamber 3" | Mac Cat-back 3" |
I.C.E is offline
post #194 of 197 Old 10-17-2017, 01:51 PM
FoxBodyNut's Avatar
Try adding the disconnect tool into the mix when you are installing it. I'll bet the inner spring on the new fitting is really tight and the fuel rail mouth is hitting it, instead of letting the spring come up and over the mouth to snap down behind that lip when things are fully seated. Does that make sense?
I.C.E likes this.
94 Vert. 359w. AFR Renegade 185, FTI open track grind, RPM2, Accufab 80mm. MM suspension. Baer/Cobra brakes. QuickTime Bell & T5-Z. Fox Longtubes, custom side-exit exhaust.
FoxBodyNut is offline
post #195 of 197 Old 10-17-2017, 02:47 PM
It makes perfect sense... thanks a bunch. I also called Russell and they said I need to make sure the spring is centered. Which all makes sense, cuz it's as if im hitting a brick wall where it should just snap in, which probably means the spring isn't centered and isn't going over the lip cuz it's tight. I'll play with it and hopefully I'll get it.
Thanks a bunch for your input.
FoxBodyNut likes this.
I.C.E is offline
post #196 of 197 Old 01-08-2018, 02:34 PM
boss 331's Avatar
So is the supply hard line and return line both 1/4". If so I will need two Russell #641303 (black) correct? As well as 640873 (black) and 640903(black) and line of course?
88 block, CHP 331 street fighter , AFR 185s, 1.6 RRs, FTI cam, RPM II intake, 70mm TB, 75mm MAF, Diablo custom tune Revolution chip, 3.73s, Viper T-56,Eibach pro-kit, bilsteins, hotchkis CC plates, UPR double adj uppers, UPR adj lowers, Polished Cobra brakes
boss 331 is offline
post #197 of 197 Old 01-10-2018, 06:37 PM
awing's Avatar
No, 5/16 feed and 1/4 return for the hard lines. I went off these part numbers https://forums.corral.net/forums/94-9...-fittings.html
95 Cobra project. Big bore 347, AFR 185, MS3, T56 in the works.
awing is offline
