Car died while driving. - Page 2 - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
post #36 of 89 Old 06-29-2019, 12:12 AM
Originally Posted by indy2000 View Post
aahhh, no.
if that were the case the CEL would come on in run and stay on in crank.....
poster has spark without spout connected, no PIP would be no spark
please edit your response.
Sorry but you are wrong. When the PIP starts failing the engine stalls. You might get code 14 but not always. Pulling the SPOUT bypasses the PIP allowing the car to run with default timing. I have seen this condition 3 or 4 times on 94-95 Mustangs GTs. Iíve owned 4 of them.
Spark with the SPOUT out, but not with the SPOUT in suggests a PIP problem. The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse.
It typically happens when the car warms up as the PIP sensor is heat sensitive. The PIP stops working and the engine dies. Wait a bit for the engine to cool and it restarts. It tends to be very erratic at first but increases in frequency until it does altogether. The first time it happened on my 94 GT it literally took me months of research to find the cause. While the PIP sensor can be replaced, it is easiest to just get a new distributor.
You have to be careful with rebuilt distributors too. They often get turned in because of the erratic PIP sensor, but this sensor is not always replaced in a rebuilt. Since it tends to fal after getting hot, it seems to pass quality check and gets sold. The new buyer then inherits another bad sensor.
More details are available here: https://www.stangnet.com/mustang-for...sensor.888218/
Flade is offline
post #37 of 89 Old 06-29-2019, 12:54 AM Thread Starter
Keep in mind I can't pull codes the ECM won't give me anything, Fuel pump is not priming at all and I have no power to the injectors when the spout is in or out. I am pretty sure this is more then just the PIP.
Lukeb_11 is offline
post #38 of 89 Old 06-29-2019, 01:36 AM
indy2000's Avatar
Flade
PIP is 0-10v square wave, that is the signal to the ICM, and ECM
Anyhoo.......the poster has NO CEL in run.........
and that stangcrap write up, is mostly incorrect.
lets return to regular program
indy2000 is offline
post #39 of 89 Old 06-29-2019, 01:45 AM
indy2000's Avatar
no power to the injectors in run, is the eec relay or power feed to the relay, fuse link G
the eec relay is turned on by the ignition switch
the ecm does not power the injectors
indy2000 is offline
post #40 of 89 Old 06-29-2019, 02:17 AM Thread Starter
I shouldn't say no power, there was about 1.5v to the injectors. but they are not firing when the engine is turned over.
Lukeb_11 is offline
post #41 of 89 Old 06-29-2019, 08:52 AM
indy2000's Avatar
during this test, where are your test leads for the 1.5volt reading?
I have found that most don't correctly place the leads, which leads to misdiagnosis
indy2000 is offline
post #42 of 89 Old 06-29-2019, 08:55 AM
indy2000's Avatar
However, we are starting to jump around, another diagnosis issue
so lets get back to the sequence, first we need to verify 5v ref.
you could have many issues,,,,,,,
indy2000 is offline
post #43 of 89 Old 06-30-2019, 07:48 PM Thread Starter
Ok I just tested all the sensors. I unplugged each sensor one at at checking volts at the act each time. The voltage remained consistent at 0.18V. What should i check next?
Lukeb_11 is offline
post #44 of 89 Old 06-30-2019, 08:38 PM
indy2000's Avatar
check power to ecm pins
then voltage drop test
from batt pos to ecm powers
then batt neg to ecm grounds
key must be in run
indy2000 is offline
post #45 of 89 Old 06-30-2019, 11:54 PM Thread Starter
which pins do i check?
Lukeb_11 is offline
post #46 of 89 Old 07-01-2019, 09:23 AM
indy2000's Avatar
power 37,57
ground 40,60
5v ref 26
indy2000 is offline
post #47 of 89 Old 07-01-2019, 08:51 PM Thread Starter
power 37,57
ground 40,60
5v ref 26
Ok so, power 37, 57 both read 1.8 volts
Pins 40 and 60 were 1.3
Pin 26 5v ref did not register at all.
Lukeb_11 is offline
post #48 of 89 Old 07-01-2019, 11:36 PM
indy2000's Avatar
and the voltage drop numbers are?
this exercise is for you. and voltage drop is far more important to understand.
so we'll continue after that.
indy2000 is offline
post #49 of 89 Old 07-02-2019, 03:16 AM Thread Starter
How would I go about doing a voltage drop test to the pins?
Lukeb_11 is offline
post #50 of 89 Old 07-02-2019, 08:39 AM
indy2000's Avatar
one lead at the power source, the battery the other lead at the corresponding pin on the ecm
ie key in run, one lead at batt pos, the other lead at the pin 37, then 57
you are going to measure the voltage drop across the wires.....
then do the same for batt neg and 40, 60
indy2000 is offline
post #51 of 89 Old 07-02-2019, 09:57 PM Thread Starter
Ok the voltage drop for pin 37 and 57 is 10 Volts each
pins 40 and 60 have no drop.
Lukeb_11 is offline
post #52 of 89 Old 07-02-2019, 10:15 PM
indy2000's Avatar
so you read 1.8volts at ecm
you have a 10volt drop
I bet your batt voltage is 11.8 volts
little low
but now you must find where the 10volts are lost.........
look at your wiring diagram, pic the easiest end to check and find that resistance.
indy2000 is offline
post #53 of 89 Old 07-02-2019, 11:03 PM Thread Starter
battery reads 12.4v. but i will look at a diagram
Lukeb_11 is offline
post #54 of 89 Old 07-02-2019, 11:07 PM Thread Starter
According to the diagram it looks like I should look at the PCM power relay. I guess I will check that next.
Lukeb_11 is offline
post #55 of 89 Old 07-03-2019, 12:20 AM
indy2000's Avatar
did you check batt voltage with key in run?
indy2000 is offline
post #56 of 89 Old 07-03-2019, 12:22 AM
indy2000's Avatar
whatever is easiest
all you need to do
key on, leave one lead on batt pos
take the other lead and follow down the line of that power wire.....
indy2000 is offline
post #57 of 89 Old 07-03-2019, 09:13 AM
first thing to do when diagnoainf anything that could be ecu related is to replace the ecu relay. I couldnt tell you the thousands Ive had replaced over the years.
Decipha is offline
post #58 of 89 Old 07-03-2019, 09:34 AM
indy2000's Avatar
we will get to that if its needed
indy2000 is offline
post #59 of 89 Old 07-08-2019, 07:50 PM Thread Starter
Ok I am back from my Tofino trip. Today I checked the pins on the ccrm. I checked Pin 8 which i believe is power going into the EEC relay it read 12.4V same as the battery. Then I checked pin 12 which is power out of the EEC relay with the key on and there is only 2V. So bad ccrm? also checked pin 11 for constant power and it is good.
Lukeb_11 is offline
post #60 of 89 Old 07-08-2019, 09:14 PM
indy2000's Avatar
i dont have a diagram so i dont know the pin numbers
if you feel that is correct, voltage drop test the power feed to it, then the ground
if there is no voltage drop, jump the ccrm with a wire to the pcm and see if it starts
indy2000 is offline
post #61 of 89 Old 07-08-2019, 09:31 PM
indy2000's Avatar
8 and 10 are power to relay line side from battery pos
12 and 24 is load side and goes to pcm pins 37, 57
indy2000 is offline
post #62 of 89 Old 07-08-2019, 09:39 PM Thread Starter
power to ccrm
10, 12 is power in, no?
The diagram I was looking at showed 8 and 10 as power in, and 12 and 24 as power out. I did do a voltage drop test and it was losing 10 volts. I will try and jump the pins and see if it starts.
Lukeb_11 is offline
post #63 of 89 Old 07-08-2019, 09:40 PM
indy2000's Avatar
power from igntion switch to
pin 13 for energizing the relay
pin 15 is the ground from ccrm to batt neg
you have some testing to do, before you call the ccrm or swap away.
indy2000 is offline
post #64 of 89 Old 07-08-2019, 09:42 PM
indy2000's Avatar
i corrected it before you posted
the drop test requires the leads on the same wire, power or ground
from one end to the other
you are losing 10volts from battery pos to pins 8 and 10??
is this correct?
indy2000 is offline
post #65 of 89 Old 07-08-2019, 09:46 PM Thread Starter
is this correct?
Pins 8 and 10 have no drop at all. pins 12 and 24 have the 10v drop.
Lukeb_11 is offline
post #66 of 89 Old 07-08-2019, 09:48 PM
indy2000's Avatar
one lead is at batt pos post and the other lead is at pin 8 and 10 and you get 10v drop
there is a problem then, what do you think it is?
indy2000 is offline
post #67 of 89 Old 07-08-2019, 09:54 PM Thread Starter
pins 8 and 10 have no drop. The power out pins 12 and 24 have a 10 volt drop from the post battery post the pin.
Lukeb_11 is offline
post #68 of 89 Old 07-08-2019, 09:54 PM
indy2000's Avatar
i think there is some confusion here
test like this
one lead batt pos other lead to 8 and 10, drop=?
one lead at 15 other at batt neg, drop=?
one lead at 12 and 24 other at 37, 57 of pcm, drop=?
one lead at 13 other at batt pos, drop=?
key in run
indy2000 is offline
post #69 of 89 Old 07-08-2019, 09:55 PM
indy2000's Avatar
okay
do the above tests and post results
indy2000 is offline
post #70 of 89 Old 07-09-2019, 12:49 PM Thread Starter
test like this
key in run
CCRM Pins 8 and 10 = no drop
CCRM pin 15 = no drop
CCRM 12 and 24 to EEC 37 and 57 = no drop
CCRM pin 13 = 11.8V drop
Lukeb_11 is offline
