Rear Fender Reflectors. Why? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 06-14-2019, 04:35 PM Thread Starter
TrickVert's Avatar
Trader Feedback: (28)
Rear Fender Reflectors: Why?
Something has always bugged me... Our tail lights already have side reflectors in them ("A" in the attached pic). Why, then, did Ford (have to?) put additional ones in the bumper cover ("B" in the pic)? Was it only to accommodate the export cars that *don't* have reflectors there?
'95 GT Vert - Rio Red - Grey Leather - Black Top
Last edited by TrickVert; 06-14-2019 at 04:49 PM. Reason: Added USA & Export comparison pic.
TrickVert is offline
post #2 of 19 Old 06-14-2019, 04:52 PM
Federal law.
tjm73 is offline
post #3 of 19 Old 06-14-2019, 05:19 PM
Saleen414's Avatar
1968 was the first year the Feds required side marker lights (front and back) on cars. Back then tail lights did not wrap around.
26 X 8.5 Hoosier
Saleen414 is offline
post #4 of 19 Old 06-14-2019, 05:34 PM Thread Starter
TrickVert's Avatar
Originally Posted by tjm73 View Post
Federal law.
Yes, which the reflectors in the taillights (or rather, on the *sides* of the taillights) should satisfy. You'll notice that there is no separate front reflector for this same reason.
post #5 of 19 Old 06-14-2019, 05:38 PM
thadude's Avatar
Probably something about the reflector having to be X distance from the wheel well or some BS. You can rest assured that could they have saved that $3 over the entire line they certainly would have.
1993 Cobra #1282
thadude is offline
post #6 of 19 Old 06-14-2019, 05:39 PM Thread Starter
TrickVert's Avatar
Yep. And the side marker light is integrated into the taillight. That's why I don't understand why the integrated reflector isn't also sufficient (unless, as I noted, it's to accommodate the export cars).
EDIT: And are the reflectors required in the offshore markets?
EDIT2: Some cars prior to '68 had wrap-around tails...
post #7 of 19 Old 06-14-2019, 08:29 PM
tjm73 is offline
post #8 of 19 Old 06-14-2019, 10:04 PM Thread Starter
TrickVert's Avatar
I'm not sure how that link is supposed to help. We've already established and agreed that side markers and reflectors are required. Since there is no auxiliary reflector on the front fender, we can safely conclude that the front side-marker/turn-signal assembly meets the requirement with its built-in reflector. Because Ford is not typically in the habit of adding superfluous items (as thadude pointed out), we can also surmise that *for some reason,* the reflector embedded in the bumper cover was a requirement. What I'm wondering is "Why?", when the tail light has *appears to have* the same side-marker/reflector function as the front.
EDIT: I decided to do a quick flash-photo experiment. Although the side of the tail light lens' lower section *appears* to be reflective (first attachment), it is not (second attachment). I think we can assume that the tail light area that did reflect the flash is likely not large enough to satisfy regulations, and that THIS is why the secondary reflector is needed. This, of course, now begs another question: Why did Ford not simply make the rest of the lower tail light section reflective instead?
P.S. Yes, I need to buff and wax again.
post #9 of 19 Old 06-14-2019, 11:28 PM
Not to be a d-hole, but who cares why. Federal safety laws require them and that was how Ford stayed compliant. Seems you are looking for some greater meaning and the answer was given but that's not enough.
Compliance. That's why.
tjm73 is offline
post #10 of 19 Old 06-15-2019, 04:29 PM Thread Starter
TrickVert's Avatar
I guess "because that's the way it is" is a satisfactory answer for you. I, on the other hand, like to try to understand the "why" and the "how" behind things. I guess that's why I tore things apart and put them back together as a kid.
My world doesn't revolve around finding the answer to this, I just wondered why Ford would add the reflector when a) it cost additional money (in both material and assembly time), and 2) from a styling perspective, it looks like there could have been another (better) solution. If it remains a mystery, then so be it, but there are a lot of people who are enthusiasts who actually *enjoy* learning the small differences and idiosyncrasies of these cars, and I thought someone may know the story. I'm not a fanatic, but I find many of them interesting.
post #11 of 19 Old 06-15-2019, 04:33 PM
HYBRED's Avatar
FWIW- they still have the rear reflector. 1994 and up.
87 coupe 5.0EFI conversion, SN95 5lug,
95 GT, V1$-Trim, NoSlow5.0's Motorsports intake, TwEECer RT & etc...
Xbox Live = TwoRockTwo
HYBRED is offline
post #12 of 19 Old 06-15-2019, 06:54 PM
I'm like that for things that actually matter. When I do get a curiosity like this I dig for an answer. But at some point, you just have to say "ok" and move on.
In this instance you've been given the single most likely reason, but it's not good enough. You can look at things two ways. 1.) there is a big complex reason for it, or 2.) the simplest reason is the reason for it.
Check out the 2019 below still there, as required by US law. Yellow turn signals are required in many offshore locations. That I know. In the UK that reflector is yellow.
tjm73 is offline
post #13 of 19 Old 06-15-2019, 07:44 PM Thread Starter
TrickVert's Avatar
... And if the 2019 had wrap-around taillights like the SN95, I'd be asking the same question, but it doesn't, so the need is obvious.
post #14 of 19 Old 06-15-2019, 09:45 PM
tjm73 is offline
post #15 of 19 Old 06-16-2019, 01:47 AM
HYBRED's Avatar
They have to have a rear light and a reflector.
File Type: jpg 2D987737-09EC-4FEF-81A6-1499A170EFB4.jpg (103.4 KB, 6 views)
HYBRED is offline
post #16 of 19 Old 06-16-2019, 06:01 PM
Michael Plummer's Avatar
Trader Feedback: (87)
Is this legal?
849rwhp and 771rwtq SAE with no Nitrous
ProCharged D1 and Snow Performance Water/Methanol
Pro-M Racing EMS
Michael Plummer is offline
post #17 of 19 Old 06-16-2019, 06:06 PM Thread Starter
TrickVert's Avatar
Originally Posted by Michael Plummer View Post
Is this legal?
Absolutely not. (But who cares?)
post #18 of 19 Old 06-16-2019, 06:13 PM Thread Starter
TrickVert's Avatar
I KNOW *a* reflector is required. I just wondered why Ford decided to....
post #19 of 19 Old 06-16-2019, 06:38 PM
HYBRED's Avatar
Because the exports had to have an amber turn signal in the lower portion of the tail light, and would still require the reflector ...
The lower portion of the US tail light is not a reflector, even though it does refract “some” light from the side
HYBRED is offline
