Great automatic transmission? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-07-2019, 10:34 PM Thread Starter
turbotoys22's Avatar
Ok planning on a 351 build with a turbo .7to 800 hp in the end.I need to start makeing some budget for the trans at trans at this point .Car is mostly a street car so what do we think is a good trans for this ?
turbotoys22 is offline
post #2 of 8 Old 05-08-2019, 10:03 AM
Someone is going to come in and say you NEED a TH400. For a mostly street car, I am not inclined to agree. But I have not built or even owned a car at that power level.
The first question is how much and what kind of street driving? Then what axle ratio and tire height will you be running? Which both lead into will you need/want an overdrive transmission or not?
Then you can look at what transmission will fit the above limits and be acceptable to build for a cost you're comfortable with.
tjm73 is offline
post #3 of 8 Old 05-08-2019, 12:24 PM Thread Starter
Thanks for the reply. 327s in the rear .with cars going 75 on the hwy and runing a 351 I dont feel I want to rev this motor like it's a honda on the hwy. So probably a overdrive transmission.
post #4 of 8 Old 05-08-2019, 12:44 PM
You should check out Silverfox Transmission and his clickclickracing forum. He's a member here too I think. A 4R70W might be the ticket.
tjm73 is offline
post #5 of 8 Old 05-08-2019, 04:28 PM Thread Starter
Thanks I looked him up looks like great stuff not bad priceing as well as long as you stay about 700 hp iylt looks like .Thanks for that information!
post #6 of 8 Old 05-09-2019, 07:22 AM
chad393na's Avatar
Trader Feedback: (99)
Totally agree. I built my own aod/4r70w for my setup (383w, s475), and it is awesome!
chad393na is offline
post #7 of 8 Old 05-09-2019, 08:00 AM Thread Starter
Chad thanks for chiming in.
post #8 of 8 Old 05-09-2019, 08:20 AM Thread Starter
Chad what rest gears are you runing?with this trsns?
For Sale TREMEC TR3550 TRANSMISSION IN GREAT CONDITION unitedmustangs Drivetrain Parts 3 04-07-2011 03:57 PM
For Sale Automatic Transmission V6 mustang 01 tooldrmr2009 V6 Parts 1 06-15-2010 05:05 AM
2010 Honda VFR to get New Dual Clutch Transmission DaHowie Lounge 11 09-10-2009 12:17 AM
what is maintenance worth to you? carpediem50 Lounge 20 04-29-2009 08:34 PM
Automatic to Manual Transmission Swap/Conversion jonjonjonjon General Mustang Tech 11 05-18-2005 09:33 AM
