94/95 mustang powerdyne ins. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-01-2019, 05:11 PM Thread Starter
I am in need to the installation instructions for the 94/95 mustang GT powerdyne supercharger install
Bryan Kernan is offline
post #2 of 9 Old 04-04-2019, 07:03 PM
Killer95Stang's Avatar
My suggestion, you need a time machine...
I did find a PDF file for the kit 86-93 kits.. that might help you out.
https://www.superchargerforums.com/a...1a52-pdf.2825/
1995 GT
Old GT40P Combo: 271rwhp & 303rwtq
New Combo: 308 rwhp 315tq N/A
-Neil Erickson (Midwest Induction) race ported GT40P's
-Neil Erickson Spec'd Custom Cam
-Ported Edelbrock RPM Intake
-Tweecer RT + Zeitronix WB
-NOS 05115 kit with 150 shot jets
Tons of other mods.. from LT's, to 10-1/2" bullits..ect..
Reach my goal of 300+rwhp NA, and now I'm aiming low 12's
Should have the dyno numbers in a couple weeks
Killer95Stang is offline
post #3 of 9 Old 04-04-2019, 07:05 PM
found this for a 94 -95 models... you need to work on your "GOOGLE-FOO" skills...
https://s1133.photobucket.com/user/r...0Manual?page=1
1995 GT
post #4 of 9 Old 04-06-2019, 11:12 PM Thread Starter
I'm really trying to figure out how exactly the alternator mounts at the bottom there and how the triangular shaped bracket mounts
post #5 of 9 Old 04-06-2019, 11:13 PM Thread Starter
Even some detailed pics of someone ls would help
post #6 of 9 Old 04-09-2019, 02:46 PM
Found this googling
j71m79 is offline
post #7 of 9 Old 04-10-2019, 10:24 AM
lankmaster82's Avatar
The triangle plate bolts to the head then the blower bracket bolts to it using spacers the one bolt screw into the head the other bolt get a nut on the back it goes in the notch of the head
lankmaster82 is offline
post #8 of 9 Old 04-13-2019, 05:18 PM
cw50's Avatar
There are 3 bolt holes on the triangle bracket. The bracket should be oriented where there's a hole close to the thermostat housing lining up with a hole in the head, one towards the motor mount and one hole towards the fender lined up with a 2nd head hole.
a. Install a long bolt, threads facing the radiator thru the bottom hole (towards motor mount) of the bracket.
b. Then install the bracket to cylinder head and secure with a bolt into the hole closet to the thermostat housing.
c. Then install a long spacer--slide onto the long bolt (a).
d. Then, tricky part: install front plate using bolt (a) & nut to hold it in place loosely, position the 2nd long spacer on the triangle bracket's 3rd hole (closest to the fender) WHILE inserting a long bolt thru the front plate, thru that spacer, thru the triangle bracket into the cylinder head.
That order is bolt --> front plate-->spacer-->triangle bracket-->cylinder head.
e. tighten the 2 bolts & nut. The nut may spin its bolt, so I use a flat screwdriver to hold the bolt head side in place from spinning.
Now for the alternator:
Hole towards the fender is simple, square ear of alt against the front plate via bolt. BUT add a washer between the ear and front plate, that optimizes the belt angle!
The other alt hole uses a short spacer and order is
bolt-->front plate --> spacer --> alt round ear --> engine mount bracket (od 1/2" wide strip metal piece --> nut)
YOU WILL NEED to clock the alternator so the 1-wire points toward the thermostat housing.
s1133.photobucket.com/user/r...0Manual?page=1 -- whoa. I forgot I still have that account. can't believe my XB1A is 14yrs old
'95GT: XB[email protected] B50-CP & Eagle forged-331ci, AFR 185s, custom cam, ported RPM2, new fuel, exhaust, MM stuff.
'02 WRX SOLD
'08 Nissan Titan Pro-4X..... '04 SVTF SOLD
'05 BLM Mustang , #645765, 16 Hands, 1 HP
cw50 is offline
post #9 of 9 Old 04-23-2019, 08:07 PM
US Army Retired
Chris94GT's Avatar
Don't forget to get some teflon lined internal belts.
94 GT
Chris94GT is offline
Mustang Interior Suspension Parts NEW OEM [email protected]@K 92mustang Suspension 6 12-06-2008 07:15 PM
Mustang adds some sizzle to Ford sales Last Mark S-197 Mustang (2005-2010) 6 06-03-2005 08:54 AM
Ive been working on a new rear suspension Justin R Road Racing/Auto X 15 01-06-2004 02:51 PM
