Does anyone have an on3 turbo setup on there 94 - 95 cobra? If so what was the power that you made and how much boost? I'm am considering purchasing the kit.
Power will soley be determined by how much boost you wanna shove in it , 8 psi expect near 400 RWHP but probably not more , shove 11-12 psi in it expect to make around 440-450 RWHP
If you want to go above that , you will need more boost which I would not advise or larger cylinder heads intake and cam along with 8-10 psi should break 500 pretty easily , typical trickflow top end kit on a fresh 306 about 8-9 psi will make 520 on a manual transmission car on a very conservative tune
I have a 306 with aluminum ford racing turbo swirl heads. I can't remember the size heads though. I wanna say that they are 58cc. Anyways thanks for the reply JT2015GT.
I have a 94 Cobra with On3 turbo with AFR heads, stock cam, Holley intake, 60lb injectors, stock cam and am running 13 psi and am close to 500 rwhp and a little over 500 tq.
Related Threads
Ford Mustang Forums
9.8M posts
200.8K members
Since 2001
