HELP ! need someone that knows F series wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-30-2007, 01:02 AM Thread Starter
351GT40's Avatar
the truck is: 94 F series
the question is:
is there a way to light up a gauge cluster (out of the truck) to see what the miles are ? ive heard that the "miles" are not stored in the odometer itself but in a separate computer located under the dash so if i change a speedo cluster the miles should be the same as what i have ? doing this for a friend that just HAS to have a tachometer
buying US silver coins pre-1965 *** '95 cobra #3787 5.8L ***
351GT40 is offline
post #2 of 3 Old 01-31-2007, 12:06 AM
Chanks7's Avatar
not sure on how to light it up off the top of my head....i can check a wiring diagram and tell you what pins to power up if that helps. However the mileage is stored in the cluster, it can only be set by a speedometer repair shop and usually they can only go up from what it currently reads.
What exactly are you trying to do??
94 GT bolt ons, 347 in the works
93 Lightning, Vortech S-trim
2003 Z71 Ext Cab LT
Chanks7 is offline
post #3 of 3 Old 01-31-2007, 02:32 AM Thread Starter
351GT40's Avatar
thanks for the reply, i figured it out though
351GT40 is offline
