moroso oil pan fitting ques.? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-23-2006, 05:00 PM Thread Starter
ok well i had decided on buying morosos oil pan mor-20520. i went ahead and told a friend of mine and about me buying it. and he told me i might have trouble fitting it under my truck. he said my truck only had a rear sump. i was wondering if any of you guys have tried this oil pan or have any idea if this front and rear sump oil pan will fit in my truck i called summit and said they really wouldnt know if it would fit or not.. also its going on a 79 block two piece rear main seal and this oil pan is for a one piece? would it matter. thanks for any help. im gonna ask around some more and see what else i can find.
heres the address on the oil pan. and if any of you guys recommend an oil pan, go ahead and tell me, im open for any suggestions.
going on a 93 f-150 swb single cab its has a 5.0 but replacing it with a 351
F1509351 is offline
post #2 of 2 Old 03-24-2006, 12:08 PM
MaverickSVT's Avatar
couldnt tell you, just going to have to check it out for your self when you get it. you can always return it right? if not trade someone.
good luck,
buddy
MaverickSVT is offline
