1st gen. electrical problems? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 12-18-2005, 11:33 AM Thread Starter
Kinda curious if anyone has experienced this so here goes. I have almost nothing electrical working in my 1994 lightning steering wheel. No horn, cruise control, the air bag code flashes 32, and the fog lights no longer work. I believe my underdrive crank pulley is the culprit. The volt gauge reads low at idle, and since most of you know that less voltage equals more amperage, then I'm guessing something burned up. A relay or something? Anyone had an experience like this?
GTTURBO88 is offline
post #2 of 7 Old 12-18-2005, 06:35 PM
Sounds like the wires that wrap around the steering wheel when you turn each way are broken. Probably best to leave it to a professional to fix so the air bag doesn't go off in your face.
The fog lights- probably just the bulbs, maybe a fuse or relay.
383svt is offline
post #3 of 7 Old 12-18-2005, 07:39 PM Thread Starter
It might even be a variety of problems. The air bag code has been flashing for a while. Then I noticed the horn and cruise didn't work. Then finally the foglights. Thanks for the input.
post #4 of 7 Old 12-22-2005, 11:38 AM
The air bag, horn and cruise are caused by the clock spring in your steering wheel being bad. When it goes, it takes all three with it. If you go to www.nloc.net and look under the Gen 1 How To's, it will explain about this and how to install a new spring. The fog lights may just be a bad fuse.
The How To's is located in the forum area under the Gen 1 heading, then it should be at the top of the list.
'94 Lightning 383ci w/Vortech S-Trim +too much to fit in the sig.
gn87gt2000 is offline
post #5 of 7 Old 12-24-2005, 02:50 PM
You might also want to try The under hood fuse panel. same thing happened to mine
(Het Jody (383)Nice spread in the mag)
RLSVT is offline
post #6 of 7 Old 12-26-2005, 09:19 AM
Thanks Ross,
When Hemmings came out to take pix. I didn't know it was going to be 5 pages and have so many pix.
Hows your truck?
Last month I ran 12.19 without the blower on, with a single carb.
my best with the blower was 10.51 @ 128.74
Jody
383svt is offline
post #7 of 7 Old 12-31-2005, 12:12 PM Thread Starter
Thank you both for the info. I will check the link and see what I can do. I will let you know how it works out.
