do 99-04 Lightning Wheels fit on 94-95 Ford F150's - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 09-03-2005, 09:12 AM Thread Starter
Question do 99-04 Lightning Wheels fit on 94-95 Ford F150's
1)I am getting a 94 F150XLT EXT. Cab Truck, I am curious if those wheels will work.
2)If they don't, will 5 lug Mustang Wheels fit on a 94-95 F150.
3)will the 93-95 Lightning Wheels fit this truck
Thanks for the help
Some_day_11's is offline
post #2 of 10 Old 09-03-2005, 06:10 PM
Mike Gager's Avatar
the 97-04 wheels have a different bolt pattern and the mustangs have a different pattern, however the 93-95 lightning wheels will bolt up no problem
BTW they do make 99-04 lightning wheels in the corerect pattern from the aftermarket
Mike Gager is offline
post #3 of 10 Old 09-04-2005, 01:14 AM
what about the hub bore? did it stay the same?
Greenbird is offline
post #4 of 10 Old 09-04-2005, 01:24 AM
The hub bore on the Gen1 and the reg 87-96 F 150 is the same. Don't know about the 97and up....
95 Lightning-Black #772
ASAP is offline
post #5 of 10 Old 09-05-2005, 02:37 AM
97 and up hub bore is differant
95 Lightning-13.957 at 94.89mph
AFR185s,Comp XE264HR-14 cam,GT40 intake,Pickrel performance Exhaust,Factory tech valvebody,TwEECer RT
Matt95L is offline
post #6 of 10 Old 09-05-2005, 11:04 PM
Thanks for the help
if your interested in the gen 1 lightning wheels.. i have a set i'll sell you. pm me if your interested
my94svtlightning is offline
post #7 of 10 Old 09-06-2005, 12:08 AM Thread Starter
I'v been told by a friend that lots of style of wheels from the Dodge Ram's will work, anybody hear this
also thanks for the replies
and 94svtlightning i sent you a pm
post #8 of 10 Old 09-06-2005, 06:54 PM
Banned Alleged Scammer
Trader Feedback: (146)
I had some adapters made for my truck . I was a little nervous using them but so far so good .
post #9 of 10 Old 09-07-2005, 05:59 AM
thesource truck looks killer
Matt95L is offline
post #10 of 10 Old 09-24-2005, 11:01 PM
Nice! First '67-'72 I've seen w/ the late Lightning wheels....
1360 is offline
