c4 conversion on a 94 lightning - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 06-28-2005, 07:26 PM Thread Starter
i was woundering if anyone has ever put a c4 transmission in a lightning before. If so what all did you have to do? Any help would be great thanks.!!!!!
my94svtlightning is offline
post #2 of 13 Old 06-29-2005, 11:47 PM
Its a waste of time. A C4 is not strong enough to carry 4500lbs. The C6 is the one you need and yes lots of people run the built c6 and have great success with them.
PurpleHaze98 is offline
post #3 of 13 Old 06-30-2005, 12:14 AM
Mike Gager's Avatar
also consider a TH400 swap. i know its blasphemy but they are very very strong and cheap to build
Mike Gager is offline
post #4 of 13 Old 06-30-2005, 11:25 AM
Go to www.NLOC.net and ask. There is a lot of guys over there running the c-6's. Dunno about the c-4's though.
95 Lightning-Black #772
ASAP is offline
post #5 of 13 Old 06-30-2005, 02:33 PM Thread Starter
even if i was to go with built c4?? i've been told that the c6's loose to much hp through them??
post #6 of 13 Old 06-30-2005, 05:05 PM
From what i was told is that the C4 is strong for a high HP light weight car but not for a heavy truck plus lots of torque and HP.
post #7 of 13 Old 06-30-2005, 10:03 PM
There has been guys who tried built c-4's and most if not all have gone to the c-6. The c-4's can't take the weight of the truck. I am converting to a built c-6 at the moment too.
CP5696 is offline
post #8 of 13 Old 06-30-2005, 11:06 PM Thread Starter
what all are you having to do?? will the netural switch and reverse lights still work or do you have to rig something up??
post #9 of 13 Old 07-01-2005, 10:05 AM
I haven't gotten that far. I just got the trans in a couple weeks ago and I'm in the middle of a rebuild so it will be a while before I put it in. I'm building a new 357 and a new single turbo setup (sold my twin turbo setup), along with the reverse manual valve body c-6 (art carr) so I have alot of work ahead of me to get things going. Go on nloc.net and ask some of the guys who have done it. They say its not a big deal at all. You have to change the trans crossbrace to one for a c-6, but other than that I"m not totally sure.
CP5696 is offline
post #10 of 13 Old 07-01-2005, 10:12 AM
Sounds like that C4 might be going in The Pony...
The Pony is offline
post #11 of 13 Old 07-01-2005, 12:35 PM Thread Starter
yeah in my pony right along with the blown 388.......
post #12 of 13 Old 07-01-2005, 05:38 PM
I have a c-6 in my truck, but the engine isn't finished yet, so I can't answer too many questions about it.
Jody
383svt is offline
post #13 of 13 Old 07-01-2005, 10:00 PM
Holy ****!!! Robby check that thing out!!
The Pony is offline
