need speedo help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-17-2005, 07:38 PM Thread Starter
need speedo help
i bought a 95 lightning that was missing drivetrain. so i got a carbed 351w and a built aod. what can i do to get that speedo working with the aodand tach to work also?
i am going to use 91 mustang mass air harness when i get the money for the parts. to get rid of the carb.
any help would be great. thanks dan
outlawdan is offline
post #2 of 4 Old 05-19-2005, 06:53 AM
If I'm not mistaken, the speedo picks up from a sensor on the rear ens, so I think your ok there.
95 Lightning-Black #772
ASAP is offline
post #3 of 4 Old 05-19-2005, 09:54 PM Thread Starter
i will check on that thanks dan
post #4 of 4 Old 05-29-2005, 06:26 AM
he is correct, on the lightning the speedo works off the exciter ring on the rear end.
383svt is offline
