speed density or mass air? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-13-2005, 11:45 PM Thread Starter
I dont know what to do? I just blew up cyl# 5. I bought a brand new short block aluminum heads cam/ roller rockers.I was told I cant tune my speed density with out a dyno!I FINALY made up my mined to convert to mass air. tried to order . I was told ford racing doesent sale anymore .can someone HELP!
dirtydanz93lightning is offline
post #2 of 8 Old 04-14-2005, 07:04 AM
You can get the harness from www.fordfuelinjection.com
Then you will need a VEX1 EEC for a 95 w/ E4OD and the MA sensor.
BTW, there has been alot of people disatisfied witht he MA conversion. The other option is to keep your SD and get a Tweecer. IT will hook into the EEC and you can adjust all engine parameters(fuel and timing curves) as well as shift points, speed limiter and rev limiter. A good example is a guy (sstock)on the NLOC.net that is running 11's with the SD and tweecer. He has 47lb injectors and blower. You can check the tweecer out at www.tweecer.com There is also a forum for help.....
Good Luck,
David
95 Lightning-Black #772
ASAP is online now
post #3 of 8 Old 04-14-2005, 04:08 PM Thread Starter
do you know what car yhe pcm is out of? I work at a ford dealership but they dont know what the numbers mean.thanks dan.
post #4 of 8 Old 04-14-2005, 05:33 PM
Its out of a 95-96 F 150. 5.0 or 5.8 with E4OD -California edition, I think.
ASAP is online now
post #5 of 8 Old 04-14-2005, 06:10 PM Thread Starter
thanks for the help!
post #6 of 8 Old 04-14-2005, 10:16 PM
I've got a Pro-m mass air conversion i'm not going to be using pm me if you're interested.
95 Lightning-13.957 at 94.89mph
AFR185s,Comp XE264HR-14 cam,GT40 intake,Pickrel performance Exhaust,Factory tech valvebody,TwEECer RT
Matt95L is offline
post #7 of 8 Old 04-14-2005, 11:34 PM Thread Starter
I gotta do some home work and scrape up some coins first!thanks
post #8 of 8 Old 04-15-2005, 05:54 PM
What is the centerline on the cam you have? S/D engines DO NOT like anything less than 113 lobe center. You can tune your engine with a chip. It is nice to have it on a dyno to tune so the a/f can be set up correctly. I have just put a turbo on my 93 Lightning and I am tuning it with Chipmaster software from Diablosport. Mass air is not the only answer.
88hatch 5.0
93Lightning turbo
2015 GT
dynoman is offline
