94 f150 what mods - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-19-2005, 11:51 PM Thread Starter
94 f150 what mods
hey people, i usually browse the 87-93 stang threads. but my friend just bought an 94 f150 with a 302. and wants to work the motor a little. i told him to do headers/cold air intake/pulleys and gears. although its an auto. might be able to do all that for less than a 800.00 what do you guys think?? also does his f150 have the holley style intake. or should he just go blower and be done with it. he doesnt want mega power. but i think he would be happy with 300rwhp. i let him drive my s-trimed stang once with 460rwhp and he had permagrin. lol
gotboostido is offline
post #2 of 9 Old 03-20-2005, 07:48 AM
800 dollars i'd get a used set of aluminum heads and then save for a cam.
95 Lightning-13.957 at 94.89mph
AFR185s,Comp XE264HR-14 cam,GT40 intake,Pickrel performance Exhaust,Factory tech valvebody,TwEECer RT
Matt95L is offline
post #3 of 9 Old 03-20-2005, 01:00 PM Thread Starter
well, the reason i told him exhaust,cold air,pulleys and gears. is because we could do everything except the gears. and we can also get a set of gt40p heads and headers for 300.00 unused.
post #4 of 9 Old 03-20-2005, 05:14 PM
Banned Alleged Scammer
Trader Feedback: (146)
If the truck has mass air then you can do all the stuff like a mustang , if it is speed density then some stuff won't work worth a crap .
post #5 of 9 Old 03-20-2005, 09:52 PM
Where can you get unused GT40P heads and headers for $300? PM me I'll buy a pair.
stangluver43 is offline
post #6 of 9 Old 03-20-2005, 10:12 PM Thread Starter
sorry a friend has them. he bought them for his stang and never used them. and needs money. i just assume they will work on the truck
post #7 of 9 Old 03-20-2005, 11:24 PM
I agree. I ran into that problem with my old 88 cougar 5.0. We had speed density, though many of the 5.0 cougar guys opted for a mass air conversion, then picked up all the HO mustang parts dirt cheap.
If it is speed density, you could always do a conversion
Cougarstang is offline
post #8 of 9 Old 03-21-2005, 03:52 AM
Most everything that'll work with mass air will work with speed density.Cam selection is limited and you need a chip or other tuning devise to use larger fuel injectors.
Matt95L is offline
post #9 of 9 Old 03-23-2005, 06:57 AM
If it is factory, it has the truck style intake which is huge! They make good tq but aftermarket intakes make a good bit more hp and tq.
I would reccomend the advice you gave, a better intake and heads, plus a 5.0HO cam advanced 2* if SD. If Mass air, go with a E303 or something similar. He will need the cam to come in around 1800 and go out at 5200(factory rev limit). The factory cams in these trucks are terribly weak!
David
95 Lightning-Black #772
ASAP is offline
