do they make a aftermarket distrbutor for lightnings - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-08-2005, 10:07 PM Thread Starter
I was just wondering because I put a 351w in my mustang and I was wondering if there was a msd distributor that fit the wiring harness?
thanks,
nathan
Nate95GT is offline
post #2 of 5 Old 03-09-2005, 05:54 PM
Well MSD makes two different 351W distributors. One will fit a mustang style ignition with the TFI module in the distributor and the trucks run the TFI module on the inner driver side fender. Accel also makes one that will work with a 351 using mustang style input. The accel is about $20 cheaper but they both are billet pieces. Just call Summit and they will get you squared away
1994 Lightning, AFR185's, Edelbrock RPM intake and Jay Allen cam.
jwbronco is offline
post #3 of 5 Old 03-09-2005, 09:38 PM Thread Starter
well on a 95 mustang gt the tfi module is also on the passenger fender.. so i don't know what to do. i recieved part # 8452 from msd which has it mounted on the distributor.
nathan
Nate95GT is offline
post #4 of 5 Old 03-12-2005, 05:30 PM
You should be able to order any dist for a 94-96 truck w/ 5.8. The only thing that makes a L dist specific is the cam gear was for a flat tappet cam. If you want a roller dist gear on the dist, get one for a 96 (F 250) w/ 5.8.
Good Luck,
David
95 Lightning-Black #772
ASAP is offline
post #5 of 5 Old 03-12-2005, 06:02 PM Thread Starter
Well I ordered the msd-8451 distributor. I think this one will work.
nathan
Nate95GT is offline
