Question about Lightning parts usable in Stang? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-03-2005, 11:49 AM Thread Starter
Just found an older Lightning that was totaled and I wanted to know if the engine and what other parts are swappable into my stang(s)?
I do know I can atleast use the long block but what else? A/C? Alternator? etc?
Procharged95* is offline
post #2 of 5 Old 03-07-2005, 01:06 PM
SVTErik529's Avatar
I saw a mustang somewhere with the complete setup in it. It was a fox body convertible. Supposedly he took the motor and bolted it right up, even using the mustang stock computer and trans. The only thing was that it needed a cowl hood. I didn't do the work or wasn't involved in it at all, but from the pics and info it looked like an easy swap. I also know a guy with a lightning motor in an F150 controlled by an A9L, so that proves that the computer can control it. It seems to me it would fit????
Erik D.
Married and Mustangless
SVTErik529 is offline
post #3 of 5 Old 03-08-2005, 09:04 AM
BallisticCoupe5L's Avatar
Yes you can use the Lightning motor in your mustang.. motor is a 351, and you can run mass air computer with it if you wanted to.. The Lightning motor has gt-40 heads and a gt-40 intake, with a little different cam than other regular 351's ... Think stock hp was around 240 or so.. I'll get you more specs later on a Lightning motor..
1979 F150 351m
1994 Cobra
2012 5.0 6 speed
2005 Harley Night Train
BallisticCoupe5L is offline
post #4 of 5 Old 03-08-2005, 09:55 AM
SVTErik529's Avatar
http://www.thebaskins.com/faq.htm#specs
Erik D.
post #5 of 5 Old 03-12-2005, 05:34 PM
All will fit. There are a few diffs such as the oil pan. All swap parts are listed in the Ford Racing catalog.
Good Luck,
David
95 Lightning-Black #772
ASAP is offline
