Which flywheel? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-17-2004, 09:02 AM Thread Starter
blksnake's Avatar
Which flywheel?
Which flywheel do I need to use with a '93 Lightning motor and 11" clutch? I'm considering using this engine in a 71 Bronco and do not know if the old flywheel is balanced correctly. I'm thinking not...
blksnake is offline
post #2 of 5 Old 07-17-2004, 11:57 AM
Mike Gager's Avatar
28 oz balance
Mike Gager is offline
post #3 of 5 Old 08-02-2004, 04:40 PM
289cobrajet's Avatar
Are you having the motor balance or is the bottom end stock?
EFI Calibrator
289cobrajet is offline
post #4 of 5 Old 08-03-2004, 12:23 AM Thread Starter
blksnake's Avatar
Well, I decided to go with a different engine than the Lightning. I found a Fox Lake 393 shortblock in the Corral classifieds. It came with a Ford Racing dampner that has a replaceable bobweight. Now my question is can I use the 28 oz bobweight that's on it since the engine has been internally balanced and I am using an "early" flywheel or do I need a 50 oz weight? The flywheel has a D1.... (1971) part number.
blksnake is offline
post #5 of 5 Old 08-03-2004, 07:06 AM
If the engine is internally balanced check with Fox Lake since it may require no weights on the balancer or flywheel, otherwise it would be a 28oz imbalance.
EFI Calibrator
