AFR 185's on '95 Lightning, PTV Clearance? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-04-2004, 07:23 PM Thread Starter
Stripper88LX's Avatar
I've got a '95 Lightning roller shortblock and I'm adding AFR 185's. Can I install an F303 and not have to flycut the pistons? If I can't run the F303, can I run an E303 and be cool on the piston to valve clearance?
Thanks guys,
Bill
Bill
1994 GT Conv 5.0L 5 Speed
Stripper88LX is offline
post #2 of 3 Old 02-07-2004, 02:47 PM
You can run any of the B,E,F,X, or Z, cams with AFR 185s an still
clear fine. But you will have to have a stall with those cams or she will be bad Lazy down low. And you will also have to have mass air with those cams. My sugestion would be get a custom grind. I went with one of Jons, cams from BENNETT racing, www.bennettracing.com, Alot of guys like Terrys cams from cammotion, with speed den, you cant go much over 220 @50 dur
and you cant go under 114 lobe sep, but you can have as much lift as you can stand!
Thanks ADAM,
Adam Red 351 is offline
post #3 of 3 Old 02-08-2004, 10:17 AM Thread Starter
Actually, this is motor is going into a '65 Mustang with a carb and a 5 speed. I just wanted to know if the PTV clearance would be in the green. The reason I asked about the FMS cams is because I already have an E and an F.
Thanks or the advice,
Bill
